Justin Deoliveira-6 wrote:
So as you stated this issue has been solved since 1.6.2... as well there
have been other wfs performance improvements relating to memory
management on 1.7.x.
I wrote that regarding the ConcurrentModificationException. i didn't find
anything related with the NoSuchElementException happening every time
Geoserver querys the database with spatial querys.
The server was restart and know it seems fine..
Some stacktrace on NoSuchElementException issue:
2009-01-15 12:39:44,167 ERROR [geotools.rendering] - Could not aquire
feature:org.geotools.data.DataSourceException: Error Performing SQL query:
SELECT "GIRID", "SCALE_FACTOR", "SUBTYPE", "ROTATION", "COLOR", "LOCATION"
FROM "GIR_INFRA_NODES" WHERE ("TYPE" = 5 AND
(SDO_RELATE("LOCATION",MDSYS.SDO_GEOMETRY(2003,27492,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-96359.4517498124,-105646.52915197912,-96255.8762501876,-105592.13084802088)),'mask=anyinteract
querytype=WINDOW') = 'TRUE' AND "SUBTYPE" = 10))
java.util.NoSuchElementException: Could not aquire
at
org.geotools.data.store.NoContentIterator.next(NoContentIterator.java:53)
at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1605)
at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:649)
at
org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1441)
at
org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1313)
at
org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
at
org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:308)
at
org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:432)
at
org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:602)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at
at
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.geotools.data.DataSourceException: Error Performing SQL
query: SELECT "GIRID", "SCALE_FACTOR", "SUBTYPE", "ROTATION", "COLOR",
"LOCATION" FROM "GIR_INFRA_NODES" WHERE ("TYPE" = 5 AND
at
org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:921)
at
org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:627)
at
org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:82)
at
org.geotools.data.store.DataFeatureCollection.openIterator(DataFeatureCollection.java:241)
at
org.geotools.data.store.DataFeatureCollection.iterator(DataFeatureCollection.java:211)
at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1591)
... 54 more
Caused by: java.sql.SQLException: ORA-29902: error in executing
ODCIIndexStart() routine
ORA-13209: internal error while reading SDO_INDEX_METADATA table
ORA-29400: data cartridge error
ORA-01591: lock held by in-doubt distributed transaction 5.11.80720
ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 286
at
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:745)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:207)
at
oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:801)
at
oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1039)
at
oracle.jdbc.driver.T4CStatement.executeMaybeDescribe(T4CStatement.java:841)
at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1134)
at
oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1274)
at
org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at
org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:910)
... 59 more
Is it not possible for you to upgrade?
I'm preparing a Geoserver 1.7.1 release with our configuration data to start
running tests. Maybe sometime soon.
Cumps,
Pedro
View this message in context: http://www.nabble.com/heavy-charge-%3D-NoSuchElementException%2C-ConcurrentModificationException-tp21480194p21481864.html
