[Geoserver-users] Height data in GeoServer
Hi List,
I’m starting to play with height data with the aim of having it available in GeoServer. The data is in ASCII grid format at this point.
My questions:
  • What file format should I be using?
  • Are there any special tricks/optimisations with raster rendering of heightmaps?
  • How do I serve height data so that things can be draped on it?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
