Hello,
I have a problem similar to that described here, but during the store definition in Geoserver:
http://seotoast.com/getting-a-java-lang-outofmemoryerror-error-while-importing-raster-files-from-postgis-to-geoserver/
I am trying to import raster data from PostGIS 2.2 to GeoServer 2.9.0.
I follow the instructions given on this link:
http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html
I used the gdal_retile to make tiles of my GTiff imagery. I configured xml files and placed them at desire place. Then I used the DDL generation utility which create 4 SQL scripts file, then I ran the SQL scripts. The image tiles importing runs correctly, but when I tried to connect the data store in Geoserver I get this error:
Caused by: java.lang.OutOfMemoryError: GC overhead limit exceeded at java.util.zip.ZipCoder.getBytes(ZipCoder.java:80) at java.util.zip.ZipFile.getEntry(ZipFile.java:310) at java.util.jar.JarFile.getEntry(JarFile.java:240) at java.util.jar.JarFile.getJarEntry(JarFile.java:223) at sun.misc.URLClassPath$JarLoader.getResource(URLClassPath.java:1005) at sun.misc.URLClassPath.getResource(URLClassPath.java:212) at java.net.URLClassLoader$1.run(URLClassLoader.java:365) at java.net.URLClassLoader$1.run(URLClassLoader.java:362) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:361) at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:510) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:441) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:403) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1969) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:255) at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:570) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:420) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:305)
The image size is almost 500MB.
If I use the same procedure with an image of 4MB size, everything works.
Could you help me, please?
Thanks for your attention.
Best regards,
Tommaso
Tommaso Pirini, PhD
Computer Engineer
email: tommaso.pirini@anonymised.com
phone: +39 340 3301299
Skype: tommy.piro24
Hi Tommaso,
you will need to dedicate more RAM (if it’s available on your computer) to the Java process running GeoServer.
The exact command depends on your platform and type of GeoServer installation (which you did not mention). You’ll have to find the correct config file/script where to put parameters for JVM and enter higher values to -Xmx switch (and its useful to adjust -Xms too), e.g.:
-Xms1024m -Xmx2048m
Peter
On 21. 9. 2016 17:16, Tommaso Pirini wrote:
Hello,
Best regards,
Tommaso
Tommaso Pirini, PhD
Computer Engineer
Skype: tommy.piro24
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Peter Kovac
IMS Programmer
MicroStep-MIS
[peter.kovac@anonymised.com](mailto:peter.kovac@anonymised.com)
