[Geoserver-users] Help integrating CAS extension
Hello everyone I am trying to integrate CAS extension in geoserver but I cant find any documentation anywhere so can anyone please help me out.
Your time and help is much appreciated.
Thanks
Vikas Mishra
MSc(Hons) Economics
Birla Institute of Technology & Science, Pilani
KK Birla Goa Campus
8412898899|vikasmishra95@anonymised.com
Lets see - working on these security modules can be difficult and is usually funded:
  1. That is an extension so it should have documentation … but does not.
  2. Checking release notes … often thank the sponsor and author
http://blog.geoserver.org/2014/05/21/geoserver-2-5-1-released/
Central Authentication Service (CAS) authentication has received a lot of QA this release and is now available in the GeoServer 2.5.x series.
Sounds like this is relatively new as an extension, and the docs were missed when it was accepted.
  1. Next step would be to contact the author … the pom.xml file for the module does not list one…
  2. Checking version history to find an author
Checking pom.xml file history:
Sep 2012 jdeolive moving cad to extension
Oct 2012 aaime Fix the build for maven 3.0.4 on Windows
etc…
So not much help, but we do know when it was promoted to extension status.
Checking a source file history:
Sep 2012 Christian Muelle Cumulative fix for GEOS-5293 GEOS-5294
So you may wish to contact Christian, perhaps he just needed sponsoring to create docs?
Jody Garnett
On Fri, Jun 13, 2014 at 6:19 PM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Hi Vikas
Unfortunately, there is no CAS documentation at the moment. Download the extension and drop the jar files into your WEB-INF/lib directory. Restart GeoServer , add an authentication filter and you should see CAS as an option. Create the CAS filter and configure it. Read the help texts reachable from the admin GUI.
Christian
On Fri, Jun 13, 2014 at 10:19 AM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Vikas
Please stay on the mailing list.
You need a CAS server, download from here
http://www.jasig.org/cas
The documentation is here
http://jasig.github.io/cas/4.0.0/index.html
Be aware of the fact that you need a SSL setup.
Christian
On Sat, Jun 21, 2014 at 11:29 AM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Hi Christian,
What should I put on at fields ‘cas server url’ since am not using any cas server so how should I put a server url?
Or do I need a cas server and if yes then can you suggest some links?
And please explain other fields as well.
Hope to hear from you soon
Thanks!
On Tue, Jun 17, 2014 at 12:24 AM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Christian,
Thanks for the heads up, I appreciate your response and
would contact you again if required regarding this matter.
Thank you!
Vikas Mishra,
BITS-Pilani Goa Campus, Goa
India
On 6/15/14, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Vikas
Please stay on the mailing list, this topic might be of interest for other people. Normally, developers do not answer personal mails.
CAS does not need an Authentication Provider, the filter should be enough. A good idea is to enable Session Creation for each filter chain containing the CAS filter.
Christian
On Wed, Jun 25, 2014 at 7:50 PM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Thanks for all your help Christian I have successfully created a SSO solution for GeoNode using this extension however I still haven’t found a way to create a Authentication Provider as CAS as when I go to add a new Authentication Provider I cant see CAS there but I can see it in FIlter chains so I have used a custom created Auth Provider and I guess that is causing problems with the Single Sign out as it still isn’t functioning properly so It would be great if you could give some work around to create a Authentication Provider and then I’m planning to write a detailed blog post on this topic.
Thanks and Cheers!
On Mon, Jun 23, 2014 at 3:56 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
Thanks!
Christian,
Thank you!
Vikas Mishra,
India
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
                 Is it possible to have a filter chain without a
authentication provider?
Here's how my security/config.xml file looks like
<security>
  <roleServiceName>default</roleServiceName>
  <authProviderNames>
    <string>customAuthProvider</string>
    <string>default</string>
  </authProviderNames>
<configPasswordEncrypterName>pbePasswordEncoder</configPasswordEncrypterName>
  <encryptingUrlParams>false</encryptingUrlParams>
  <filterChain>
    <filters name="web"
class="org.geoserver.security.HtmlLoginFilterChain"
interceptorName="interceptor" exceptionTranslationName="exception"
path="/web/**,/gwc/rest/web/**,/" disabled="false"
allowSessionCreation="true" ssl="false" matchHTTPMethod="false">
      <filter>CasAuthenticationFilter</filter>
      <filter>rememberme</filter>
      <filter>form</filter>
      <filter>anonymous</filter>
    </filters>
    <filters name="webLogin"
class="org.geoserver.security.ConstantFilterChain"
path="/j_spring_security_check,/j_spring_security_check/" disabled="false"
    </filters>
    <filters name="webLogout"
class="org.geoserver.security.LogoutFilterChain"
path="/j_spring_security_logout,/j_spring_security_logout/"
disabled="false" allowSessionCreation="True" ssl="false"
      <filter>formLogout</filter>
    </filters>
    <filters name="rest"
class="org.geoserver.security.ServiceLoginFilterChain"
interceptorName="restInterceptor" exceptionTranslationName="exception"
path="/rest/**" disabled="false" allowSessionCreation="true" ssl="false"
      <filter>basic</filter>
    </filters>
    <filters name="gwc"
path="/gwc/rest/**" disabled="false" allowSessionCreation="True"
    </filters>
    <filters name="test"
path="/test" disabled="false" allowSessionCreation="true" ssl="false"
    </filters>
    <filters name="default"
path="/**" disabled="false" allowSessionCreation="true" ssl="false"
    </filters>
  </filterChain>
  <rememberMeService>
<className>org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices</className>
    <key>geoserver</key>
  </rememberMeService>
</security>
Now here if I remove the "customAuthProvider" I get a "Java Integrity
error", so I guess it does need it, any ideas?
On Thu, Jun 26, 2014 at 12:44 PM, Christian Mueller <
Hi Vikas
the CAS filter.
Christian
solution for GeoNode using this extension however I still haven't found a
causing problems with the Single Sign out as it still isn't functioning
a Authentication Provider and then I'm planning to write a detailed blog
post on this topic.
Thanks and Cheers!
Hi Vikas
Christian
wrote:
Hi Christian,
                 What should I put on at fields 'cas server url' since
Thanks!
> wrote:
Christian,
Thank you!
Vikas Mishra,
India
wrote:
> Hi Vikas
the
Restart
> Christian
but I
out.
>> Thanks
>> Vikas Mishra
>> MSc(Hons) Economics
>> *Birla Institute of Technology & Science,* Pilani
>> KK Birla Goa Campus
Solutions
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
No, no need for the customAuthProvider. Did you remove this provider using the admin GUI ? Editing the config xml files directly circumvents the validation code.
You should remvoe the remeberMe service, otherwise the logout cannot succeed.
Christian
On Thu, Jun 26, 2014 at 9:32 AM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Hi Christian,
Is it possible to have a filter chain without a authentication provider?
Here’s how my security/config.xml file looks like
default
customAuthProvider
default
pbePasswordEncoder
false
rememberme
form
anonymous
form
formLogout
basic
anonymous
basic
geoserver
Now here if I remove the “customAuthProvider” I get a “Java Integrity error”, so I guess it does need it, any ideas?
On Thu, Jun 26, 2014 at 12:44 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Thanks and Cheers!
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
Thanks!
Christian,
Thank you!
Vikas Mishra,
India
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
You mean to say that I should remove the auth Provider from GUI and not directly from the config file?
On Thu, Jun 26, 2014 at 3:55 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
default
customAuthProvider
default
pbePasswordEncoder
false
rememberme
form
anonymous
form
formLogout
basic
anonymous
basic
geoserver
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Thanks and Cheers!
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
Thanks!
Christian,
Thank you!
Vikas Mishra,
India
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Exactly. Before storing, Geosever validates your configuration. This is not possible if you modify the XML file directly.
On Thu, Jun 26, 2014 at 12:57 PM, Vikas Mishra <vikasmishra95@anonymised.com> wrote:
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
default
customAuthProvider
default
pbePasswordEncoder
false
rememberme
form
anonymous
form
formLogout
basic
anonymous
basic
geoserver
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Thanks and Cheers!
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
Thanks!
Christian,
Thank you!
Vikas Mishra,
India
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Single sign out is still not working, If I understood it correctly, single sign out works in a way that once we go to the logout url of the cas server it should logout the geoserver, but If I go to https://my.cas.server/logout it gives me a logout succesfull but it still doesn’t logout of geoserver
Here is my new config xml file
default
pbePasswordEncoder
false
form
basic
anonymous
form
formLogout
basic
anonymous
basic
anonymous
basic
anonymous
geoserver
And I removed remember me filter chain but I cant find a way in GUI to remove the rememberMeService at the end of the config.xml if that’s what you meant by 'remove remember me service"
On Thu, Jun 26, 2014 at 4:43 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
On Thu, Jun 26, 2014 at 12:57 PM, Vikas Mishra <vikasmishra95@anonymised.com.> wrote:
On Thu, Jun 26, 2014 at 3:55 PM, Christian Mueller <christian.mueller@anonymised.com…5445…> wrote:
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
default
customAuthProvider
default
pbePasswordEncoder
false
rememberme
form
anonymous
form
formLogout
basic
anonymous
basic
geoserver
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Thanks and Cheers!
Hi Vikas
Christian
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Hi Christian,
Thanks!
Christian,
Thank you!
Vikas Mishra,
India
Hi Vikas
Christian
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
I do not believe the sign out process for CAS works like you expect.
While it is true that doing a logout from GeoServer *may* send you to
CAS to kill the CAS session; however, the opposite is not true.
Just because you go to your CAS server and logout does not, and should
not log you out of GeoServer. The intent is that you would have many
web application that all use CAS. Logging out of one web application
that uses CAS should not immediately log you out of all other web
applications (that use CAS) which you may have open in other browser
windows.
it gives me a logout succesfull but it still doesn't logout of geoserver
<security>
  <filterChain>
    <filters name="web" class="org.geoserver.security.HtmlLoginFilterChain"
    </filters>
allowSessionCreation="false" ssl="false" matchHTTPMethod="false">
    </filters>
disabled="false" allowSessionCreation="false" ssl="false"
    </filters>
    </filters>
    <filters name="gwc"
path="/gwc/rest/**" disabled="false" allowSessionCreation="true"
    </filters>
    </filters>
    </filters>
  </filterChain>
  <rememberMeService>
</security>
remove the rememberMeService at the end of the config.xml if that's what
validation code.
succeed.
Christian
wrote:
Hi Christian,
<security>
  <authProviderNames>
  <filterChain>
    <filters name="web"
    </filters>
    </filters>
    </filters>
    </filters>
    <filters name="gwc"
    </filters>
    </filters>
    </filters>
  </filterChain>
  <rememberMeService>
</security>
Hi Vikas
Christian
post on this topic.
Thanks and Cheers!
Hi Vikas
Christian
Hi Christian,
links?
Thanks!
Christian,
and
Thank you!
Vikas Mishra,
India
wrote:
Hi Vikas
Download the
directory. Restart
as an
texts
Christian
geoserver but I
me out.
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Solutions
Exploration
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
Single Log Out should work as expected by Vikas.
See
http://jasig.github.io/cas/4.0.0/installation/Logout-Single-Signout.html
Maybe a bug, I have to investigate.
Christian
On Fri, Jun 27, 2014 at 2:03 PM, Cliff Ingham <inghamn@anonymised.com> wrote:
While it is true that doing a logout from GeoServer may send you to
windows.
default
pbePasswordEncoder
false
<filters name=“web” class=“org.geoserver.security.HtmlLoginFilterChain”
interceptorName=“interceptor” exceptionTranslationName=“exception”
path=“/web/,/gwc/rest/web/,/” disabled=“false”
allowSessionCreation=“true” ssl=“false” matchHTTPMethod=“false”>
form
basic
anonymous
<filters name=“webLogin”
class=“org.geoserver.security.ConstantFilterChain”
path=“/j_spring_security_check,/j_spring_security_check/” disabled=“false”
allowSessionCreation=“false” ssl=“false” matchHTTPMethod=“false”>
form
<filters name=“webLogout”
class=“org.geoserver.security.LogoutFilterChain”
path=“/j_spring_security_logout,/j_spring_security_logout/”
disabled=“false” allowSessionCreation=“false” ssl=“false”
formLogout
<filters name=“rest”
class=“org.geoserver.security.ServiceLoginFilterChain”
interceptorName=“restInterceptor” exceptionTranslationName=“exception”
path=“/rest/**” disabled=“false” allowSessionCreation=“true” ssl=“false”
basic
anonymous
<filters name=“gwc”
path=“/gwc/rest/**” disabled=“false” allowSessionCreation=“true”
basic
anonymous
<filters name=“test”
path=“/test” disabled=“false” allowSessionCreation=“true” ssl=“false”
<filters name=“default”
path=“/**” disabled=“false” allowSessionCreation=“true” ssl=“false”
basic
anonymous
geoserver
validation code.
succeed.
Christian
wrote:
Hi Christian,
default
customAuthProvider
default
pbePasswordEncoder
false
<filters name=“web”
rememberme
form
anonymous
form
disabled=“false” allowSessionCreation=“True” ssl=“false”
formLogout
basic
anonymous
<filters name=“gwc”
path=“/gwc/rest/**” disabled=“false” allowSessionCreation=“True”
basic
geoserver
Hi Vikas
Christian
post on this topic.
Thanks and Cheers!
Hi Vikas
Christian
Hi Christian,
links?
Thanks!
Christian,
and
Thank you!
Vikas Mishra,
India
On 6/15/14, Christian Mueller <christian.mueller@anonymised.com.>
wrote:
Hi Vikas
Download the
directory. Restart
as an
texts
Christian
geoserver but I
me out.
Thanks
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Solutions
Exploration
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
Vikas Mishra
MSc(Hons) Economics
KK Birla Goa Campus
