I’m a geoserver newbie and I’m trying to make a mosaic using the mosaicindexbuilder tool included in gt-imagemosaic-2.5.5.jar installed in C:\GeoServer 1.7.4\webapps\geoserver\WEB-INF\lib.
I’m running it on the cmd and this was the command:
C:\GeoServer 1.7.4\webapps\geoserver\WEB-INF\lib> java -jar gt-imagemosaic-2.5.5
.jar MosaicIndexBuilder -s C:\GeoServer 1.7.4\data_dir\coverages\ortos -w *.t
if -name test
This is the error message that appears to me:
Failed to load Main-Class manifest attribute from gt-imagemosaic-2.5.5.jar
What I’m doing wrong? Do you have any tips for me to build the mosaic?
Is there any other way to build a mosaic from .tiff images in geoserver?
Thank you in advance,
Toze
It looks like just the running of the command is wrong. Using the -jar command will look for a class to run in the manifest. If you use a command like:
java -cp "gt-imagemosaic-2.5.5.jar;<rest of geotools libs>" org.geotools.utils.imagemosaic.MosaicIndexBuilder <options>
Then it should work. Although I could be wrong, I have never actually run it. You may want to check out:
http://geoserver.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
Simone: is there an easier way to run it? I seem to remember something about the image mosaic plugin building up the mosaic on the fly?
Antonio Jose Silva (Toze) wrote:
I'm a geoserver newbie and I’m trying to make a mosaic using the mosaicindexbuilder tool included in gt-imagemosaic-2.5.5.jar installed in C:\GeoServer 1.7.4\webapps\geoserver\WEB-INF\lib\.
I'm running it on the cmd and this was the command:
C:\GeoServer 1.7.4\webapps\geoserver\WEB-INF\lib> *java -jar gt-imagemosaic-2.5.5
.jar MosaicIndexBuilder \-s C:\GeoServer 1.7.4\data_dir\coverages\ortos \-w \*.t
if \-name test*
*Failed to load Main-Class manifest attribute from **gt-imagemosaic-2.5.5.jar*
Toze
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited royalty-free distribution of the report engine for externally facing server and web deployment. http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
The imageosiac-jdbc has also some utilites.
I solved the problem with the jar files in the manifest. Look at the pom.xml
The advantage is that you can use java -jar gt-imagemosaic-jdbc.ar without setting the classpath.
Justin Deoliveira writes:
if \-name test*
Toze
Justin Deoliveira
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com _______________________________________________
