[Geoserver-users] Help needed to test on firefox, chrome, ie
A direct link for finding the issue faster:
http://jira.codehaus.org/browse/GEOS-6948
I tested the nightly build with Firefox 36.0.4 on Windows and fix seems to be OK and the active area is only the check box.
However, an opposite issue that prevents changing the status of some check boxes with Firefox is still there
http://jira.codehaus.org/browse/GEOS-6036
This can be tested with the “img_sample2” store at http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.data.store.CoverageStoreEditPage&storeName=img_sample2&wsName=nurc
Same issue with the “Enabled” and “Use HTTP connection pooling” boxes in the WMS store page. This is easy to test by starting to create a new WMS store from http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.data.store.WMSStoreNewPage
I found some time ago that the generated html page in the user interface has some extra and if I removed that with Firebug the check box started to listen to me. This is reported in this mail
http://article.gmane.org/gmane.comp.gis.geoserver.devel/28492
Because of this issue these settings can’t be edited at all with Firefox. IE 10 is OK.
-Jukka Rahkonen-
Jody Garnett wrote:
Quick request from the devel list for help testing the nightly build for an interesting fix!
  • GEOS-6948 GeoServer UI accepts check box clicks outside the boxes
To test please download an appropriate release from http://geoserver.org/release/master/ and reply to this email.
This change applies to any and all configuration screens that have a checkbox. They should now only respond when the checkbox is clicked (and not the nearby label).
Thanks to Eva Shon (from Boundless New York) addressing this long standing issue.
Jody Garnett
So there is still some work to do for Firefox.
Any problem back porting this change to stable?
On 1 April 2015 at 00:21, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Jody Garnett
Jody Garnett
Might a better fix be to change the CSS to make the checkbox and label inline? As it is they are both block and then are repositioned using the margins of the label so that they are positioned the way they would have been if inline. That way we retain the ability to click on the label, but the label doesn’t extend across the width of the page.
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Jody Garnett
-Jukka Rahkonen-
Jody Garnett
Kevin Smith
Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
http://boundlessgeo.com/
I have merged Kevin’s fix onto master, if you would like to confirm the fix on a nightly build Jukka we can back port this to stable.
Jody Garnett
On 1 April 2015 at 14:41, Jody Garnett <jody.garnett@anonymised.com84…> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
Jody Garnett
-Jukka Rahkonen-
Jody Garnett
Works for me with the latest nightly (git rev.
86a048b5e0092285d1d968f6f4d5c3911673d766)
-Jukka-
Jody Garnett
Jody Garnett
-Jukka Rahkonen-
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Fri, Apr 3, 2015 at 8:21 PM, Rahkonen Jukka (MML) <
Good job Eva, Kevin and Jody! :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Backported 6036 to 2.7.x Cant update the ticket since JIRA’s locked and it hasn’t been transferred to the new JIRA yet.
On 3 April 2015 at 11:34, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Apr 3, 2015 at 8:21 PM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Tue, Apr 7, 2015 at 2:01 AM, Kevin Smith <ksmith@anonymised.com> wrote:
Backported 6036 to 2.7.x Cant update the ticket since JIRA's locked and
it hasn't been transferred to the new JIRA yet.
I've been told it will be fully operational next week... please take a note
to update it then
Ing. Andrea Aime
@geowolf
Technical Lead
