[Geoserver-users] Help, please!
I have a lot of problems using external data directory in GS 1.7. When I
change from 1.6.2 to 1.6.3 all works ok but when I try use 1.7 with the same
data directory TIFs don't show it, entities disapear... I can't understand
anything. I must change something more apart GEOSERVER_DATA_DIR parameter in
web.xml? Is catalog.xml from 1.6.3 working directly in 1.7? Is catalog.xml
from 1.6.3 fully compatible with 1.7?
I've try with WinXP; java JDKs 1.5.0_08 and 1.6.0_10; Apache Tomcat 5.5.27
and 6.0.18.
Thanks in advance.
View this message in context: http://www.nabble.com/Help%2C-please!-tp20464359p20464359.html
Ciao Alfonso,
we probably failed a bit on the communication side of things.
When you update from the 1.6 to 1.7 you need to replace the old
raster.sld with the one you find here [1] since in 1.7. we have
implemented the raster symbolizer, hence the old raster style is not
ignored anymore and depending on the structure of your raster data,
you can run into problems.
Simone
[1] https://svn.codehaus.org/geoserver/branches/1.7.x/configuration/release/styles/raster.sld
On Wed, Nov 12, 2008 at 5:52 PM, Alt <alfonso.fraguas.bravo@anonymised.com> wrote:
and 6.0.18.
Thanks in advance.
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
Thank you very much. The nighmare finished. Now all works fine with the correct SLD.
All the best, Alt
Simone Giannecchini escribió:
Ciao Alfonso,
Simone
and 6.0.18.
Thanks in advance.
