[Geoserver-users] help to deploy geoserver on weblogic
how can i deploy gerserver jar file in weblogic successfully?
What have you tried? Which version of each?
A quick google suggests others have managed it though no obvious documentation seems apparently.
I’d suggest:
http://weblogicserveradministration.blogspot.co.uk/2011/07/web-applications-basics-war-files.html
and
http://docs.oracle.com/cd/E19424-01/820-4807/war-weblogic/index.html
might be starting places. It doesn’t seem there’s anything GeoServer specific.
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Jonathan
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
