Dear,
I'm trying to use JQuery autocomplete showing json data retrieved from a GetFeature request to a Geoserver,
but i have problems.
I have set ENABLE_JSONP system variable to true.
This is my code:
<input id="input" name="muni_name" type="text" style="width: 200px;">
<input id="muni-input" name="muni_code" type="text" style="width:100px;" readonly>
<script type='text/javascript'>
$(function () {
$("#input").autocomplete({
source: function (request, response) {
$.ajax({
url: "http://localhost:8080/geoserver/ows",
dataType: "jsonp",
data: {
typename: "municipios",
propertyName: "municipio,codigo",
outputformat: "text/javascript",
service: "wfs",
version: "1.0.0",
request: "GetFeature",
cql_filter: "municipio ILIKE '" + request.term + "%'"
success: function () {
response($.map(data.features, function (item) {
alert( item);
return {
// following property gets displayed in drop down
label: item.id,
// following property gets entered in the textbox
value: item.id,
// following property is added for our own use
code: item.codigo
minLength: 5,
select: function (event, ui) {
if (ui.item) {
$("#muni-input").val(ui.item.code);
</script>
The problem, there are not a callback function parseResponse (default callback funtion of geoserver).
How can i do to solve this?
Define a parseResponse() function out of $() function, and how to link results to success event of Jquery ui?
Miguel A. Manso
Hi Miguel,
I think you can add an to the jquery ajax call to let jquery itself handle the jsonp stuff. The option is:
jsonp: ‘parseResponse’
Then your success function should be called upon Geoserver response.
Mauro
2013/10/25 Miguel-Angel Manso-Callejo (UPM) <m.manso@anonymised.com5955…>
Dear,
I’m trying to use JQuery autocomplete showing json data retrieved from a
This is my code:
Miguel A. Manso
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Mauro
Finnaly, after several hours i can do
I must put in*$ajax({*
two options.
* jsonp: "false",**
** jsonpCallback: "parseResponse",*
Thank you, very much
Miguel A.
El 26/10/2013 9:45, Mauro Bartolomeoli escribió:
Hi Miguel,
jsonp: 'parseResponse'
Mauro
2013/10/25 Miguel-Angel Manso-Callejo (UPM) <m.manso@anonymised.com <mailto:m.manso@anonymised.com>>
Dear,
from a
This is my code:
200px;">
$(function () {
$.ajax({
dataType: "jsonp",
data: {
service: "wfs",
version: "1.0.0",
request.term + "%'"
alert( item);
return {
drop down
label: item.id <http://item.id>,
textbox
value: item.id <http://item.id>,
our own use
code: item.codigo
minLength: 5,
if (ui.item) {
</script>
Miguel A. Manso
the most from
register >
<mailto:Geoserver-users@lists.sourceforge.net>
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
