Hi all;
I had geoserver working all fine and this morning I was going to get at the maps. But before I got too much in it I thought I would download and get the current version — oops!
Now I get the following on start up and a 404 error when I try the admin page.
Many thanks for any help
Kelly
./startup.sh
GEOSERVER_HOME environment variable not found, using current
location. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /usr/local/geoserver/data_dir/data/
2 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com0… via org.mortbay.log.Slf4jLog
917 [main] INFO org.mortbay.log - jetty-6.0.1
4280 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
4280 [main] INFO /geoserver - Loading Spring root WebApplicationContext
4367 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/local/geoserver/webapps/geoserver/WEB-INF/lib/main-1.6.3.jar!/applicationContext.xml]
1 [main] INFO org.geotools.factory - Factory implementations for category FilterFactory:
org.geotools.filter.FilterFactoryImpl
3 [main] INFO org.geotools.factory - Factory implementations for category StyleFactory:
org.geotools.styling.StyleFactoryImpl
4660 [main] INFO org.springframework.core.CollectionFactory - JDK 1.4+ collections available
4671 [main] INFO org.springframework.core.CollectionFactory - Commons Collections 3.x available
4701 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/local/geoserver/webapps/geoserver/WEB-INF/lib/wcs-1.5.0-RC4.jar!/applicationContext.xml]
4717 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
java.lang.VerifyError: (class: org/vfny/geoserver/global/WCS, method: signature: ()V) Incompatible object argument for function call
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:242)
at org.springframework.util.ClassUtils.forName(ClassUtils.java:88)
at org.springframework.beans.factory.support.BeanDefinitionReaderUtils.createBeanDefinition(BeanDefinitionReaderUtils.java:65)
at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitionElement(DefaultXmlBeanDefinitionParser.java:369)
at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitionElement(DefaultXmlBeanDefinitionParser.java:335)
at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitions(DefaultXmlBeanDefinitionParser.java:266)
at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.registerBeanDefinitions(DefaultXmlBeanDefinitionParser.java:186)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:246)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:163)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:125)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:141)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:126)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:94)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:89)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:268)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:450)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1129)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:420)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:457)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:40)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:156)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:120)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:119)
at org.mortbay.jetty.Server.doStart(Server.java:210)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:905)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
4722 [main] ERROR org.mortbay.log - failed ContextHandler@anonymised.com{/geoserver,file:/usr/local/geoserver/webapps/geoserver/}
4724 [main] ERROR org.mortbay.log - failed ContextHandlerCollection@anonymised.com
4745 [main] ERROR org.mortbay.log - failed HandlerCollection@anonymised.com
4871 [main] INFO org.mortbay.log - Started SelectChannelConnector @ 0.0.0.0:1966
4879 [main] ERROR org.mortbay.log - failed Server@anonymised.com
java.lang.reflect.InvocationTargetException
Caused by: java.lang.VerifyError: (class: org/vfny/geoserver/global/WCS, method: signature: ()V) Incompatible object argument for function call
