[Geoserver-users] help
Hi, I am trying to install GeoServer on WebSphere 8.0 but I frame errors libraries.
Installing the EAR file is done correctly, the problem is when I try to run GeoServer in WebSphere.
Someone to GeoServer installed in WebSphere 8.0 for I indicate where the error may be
Hi Rogelio
I think you mean a WAR file.
Do you see something in SystemOut.log
Christian
On Wed, Jul 16, 2014 at 1:32 AM, Rogelio Sánchez Bonilla <rogeliosb@…95…> wrote:
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Rogelio
Please stay on the mailing list. Normally, developers do not answer to private mails.
Your SystemOut.log indicates that geoserver is not started. Your screenshot (Enterprise Apps) shows an item “geoserverEAR”. How did you create the ear file ?.
I would delete the enterprise app and install a web application using the geoserver.war contained in the zip file file located here:
http://sourceforge.net/projects/geoserver/files/GeoServer/2.5.1/geoserver-2.5.1-war.zip
Christian
On Wed, Jul 16, 2014 at 8:29 PM, Rogelio Sánchez Bonilla <rogeliosb@anonymised.com> wrote:
hi Christian
I add SystemOut.log file and
files in the WAS console and browser when I run GeoServer
As you will see the error but I do not check that screen displays with rare characters
Date: Wed, 16 Jul 2014 11:24:18 +0200
Subject: Re: [Geoserver-users] help
To: rogeliosb@anonymised.com…
CC: geoserver-users@lists.sourceforge.net
Hi Rogelio
Christian
