[Geoserver-users] Hi and question.
Hello people
I’m newbie…
I have an shp (with shx,dbf and prj)
Dbf structure
Have
GEOCODIGO, NOME, AREA_TOT_G
Geocodigo= the shape code
Nome= name
Area_tot_g= total area
I have the info but how could I make a map with both the name and the area.
Also want to make an degrade of colors ( if the area is greater than 150000 blue, if is between 150000 and 1000000 red, etc…).
There is any way to take de shp info for the polygon and link them to mysql database?
Thanks
Eduardo Barasch
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.16.13/1169 - Release Date: 3/12/2007 22:56
Hi Eduardo,
Welcome!! My responses to your questions are inline.
BALA wrote:
Hello people
I’m newbie…
Dbf structure
Have
Nome= name
I would first check out the following tutorial:
http://docs.codehaus.org/display/GEOSDOC/User+Tutorial+Shapefile
150000 blue, if is between 150000 and 1000000 red, etc..).
Both of these are done with "SLD", the styling language used by
GeoServer. In your GeoServer installation (I assume you are running from
the windows exe), look at <geoserver
install>/data_dir/styles/popshade.sld for an example.
mysql database?
The easiest way would be with ogr2ogr. See
http://www.gdal.org/ogr/drv_mysql.html for an example.
Check out that info and let us know if you have any more questions.
-Justin
Thanks
Eduardo Barasch
!DSPAM:4007,47599db0171551637810514!
3/12/2007 22:56
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
