I can´t see the option SDE in the storages, I paste in the carpet the jar of SDE and then when run the start geoserver say me
"58501 [ADVERTENCIA] org.geotools.data.arcsde.arcSDEDataStoreFactory - ArcSDE Java API seems to not be on your classpath. Please verify that all needed jars are.
ArcSDE data stores will not be available.
java.lang.NoClassDefFoundError
at org.geotools.data.arcsde.arcSDEDataStoreFactory.class$ArcSDEDataStoreFactory.java:40
at org.geotools.data.arcsde.arcSDEDataStoreFactory.isAvailable$ArcSDEDataStoreFactory.java:218
at
org.geotools.data.arcsde.arcSDEDataStoreFactory.class$<ArcSDEDataStoreFactory.java:40>
at
org.geotools.data.arcsde.arcSDEDataStoreFactory.isAvailable$<ArcSDEDataStoreFactory.java:218>
at
at
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
If "N14" in "WGS85 N14" means UTM zone 14 (North), then your SRS is not 4326, which stands for geodetic lat/lon coordinates. The correct SRS might be 32614, but I am not sure.
-Jukka Rahkonen-
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net on behalf of ajuarez
Sent: Tue 18.9.2007 18:53
Subject: Re: [Geoserver-users] Hi SDE
Hi... is working now, thanks... but when I try see the layers don´t appear
me, I use several SRS but must be the 4326 (WGS84 N14)...
any could helpme thanks
Continuum-3 wrote:
Hi Arturo,
It looks like the arcsde drivers have not been installed. There are
instructions on how to do this here:
at
at
yes is right, but I use in the SDE WGS84 UTM 14 north, not WGS85... I tried
with 32614 but neither it work
Rahkonen Jukka wrote:
-Jukka Rahkonen-
Continuum-3 wrote:
Hi Arturo,
at
at
