[Geoserver-users] Hibernate with PostGIS
I’m starting a new project, and I will use Hibernate to mapping the classes.
But, I have a some classes with spatial data.
I would like to know if somebody already passed therefore and has an example class. I’m using PostGIS.
Best regards,
Fernando Quadro
http://www.fernandoquadro.com.br
fsquadro@anonymised.com
Receba as últimas notícias do Brasil e do mundo direto no seu Messenger com Alertas MSN! É GRÁTIS! Assine já!
People have done it before, obviously, so it should be possible.
http://www.nabble.com/PostGIS---hibernate---EJB3-t2064211.html
I'd be interested in your hopefully successful attempts.
Regards
Per-Olof Norén
Fernando Quadro skrev:
I'm starting a new project, and I will use Hibernate to mapping the classes.
I would like to know if somebody already passed therefore and has an example class. I'm using PostGIS.
Best regards,
Fernando Quadro
Receba as últimas notícias do Brasil e do mundo direto no seu Messenger com Alertas MSN! É GRÁTIS! Assine já! <http://alertas.br.msn.com/&gt;
Geoserver-users mailing list
Hi Fernando,
As Per-Olaf states its definitely been done before. I have used
hibernate with geoserver but not to map spatial data.
I know Andrea and Jody worked on a project last year that involved using
hibernate to map relational data into features... similar to what
geotools datastores do. I think at one point there was even a hibernate
datastore... but not sure where that code is living now.
-Justin
Per-Olof Norén wrote:
Regards
Per-Olof Norén
classes.
Best regards,
Fernando Quadro
!DSPAM:4007,46ceedff115967082231907!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
The code did not have an open source header on the top of it but we can at least answer questions about how it was done. As I understand it we used the GeoTools sql writers to generate the spatial query; and we added that into the Hibernate Criteria object. Mapping from PostGIS WKB to a JTS Geometry object was done as a UserType.
You can use the GeoTools Feature / FeatureType constrct a bit like a dynamic bean....
Jody
Justin Deoliveira wrote:
Hi Fernando,
-Justin
Hey Guys,
Sorry this is a vague post, Im not in a position right now to be too precise. We did this sucessfully last year with EJB3/Hibernate to PostGIS… We used EJB3Spatial. Norman Baker is the author and when I used it he was working on this under the PostGIS project/repository/license. Basic explaination is you need to use the PostGIS jdbc driver and add some @ com.postgis.GeometryType annotations, and the com.postgis.GeometryType class to your beans.jar
It works very well, but last time I checked you had to still manually create the database tables & geom columns. Also, make sure your versions of postgis, matches your jdbc driver version!
There are two other projects floating around that are also supposed to do this… I don’t have time to look right now, and I can’t confirm if they are pure vapour!
See one here…
http://www.cadrie.com/projects/majas-hibernate/hibernate-spatial/source-repository.html
Gotta run,
dynamic bean…
Jody
Hi Fernando,
hibernate to map relational data into features… similar to what
datastore… but not sure where that code is living now.
-Justin
