I have some layers in geoserver and I want to hide some features on
identify tool of geoexplorer. Is possible to do this or I need to modify my
original data on postgresql?
I´m looking for but I don't find anything about this option.
Thanks!
Aitor Freire Astray
I don´t know which kind of GetFeatureInfo-format GeoExplorer is using. There are two main types available:
a) You get the getFeatureInfo from Geoserver in HTML-format. Geoserver is creating the layout based on the GetFeatureInfo-templates (see http://docs.geoserver.org/stable/en/user/tutorials/GetFeatureInfo/index.html for more on this). If you want to remove certain attributes from the response you can simply create a custom FeatureInfo-template for the specific layer
b) The client itself (in this case geoexplorer) is responsible for the layout and receives only the raw data from Geoserver (i.e. all attributes and their values plus maybe also the geometry). As far as I know there´s no possibility to limit which features/attributes shall be displayed in your GetFeatureInfo other than removing them from the data itself.
Best regards
Max Stephan
From: Aitor Freire Astray [mailto:aitor.freire@anonymised.com]
Sent: 19 December 2012 11:19
Subject: [Geoserver-users] hide features
I have some layers in geoserver and I want to hide some features on identify tool of geoexplorer. Is possible to do this or I need to modify my original data on postgresql?
I´m looking for but I don’t find anything about this option.
Thanks!
Aitor Freire Astray
Hey,
Please try to determine first how GeoExplorer handles GetFeatureInfo-requests (e.g. through firebug). But you should usually see at first sight if it´s the standard-HTML-response (like in Geoserver´s layer preview) or a customized one within GeoExplorer.
Best regards
Max Stephan
Sent: 19 December 2012 12:59
To: Max Stephan
Subject: Re: [Geoserver-users] hide features
Hi Max,
I’ll try to do it.
Thanks!!
2012/12/19 Max Stephan <max.stephan@anonymised.com>
Best regards
Max Stephan
Thanks!
Aitor Freire Astray
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
Geoserver-users@anonymised.comforge.net
Aitor Freire Astray
