Hi everyone,
Am starting to use GeoServer. Is there a way for me to remove/hide the
zoom blue bar on the left hand side. I dont want the user to be able
to zoom in or zoom out.
Thanks.
Hi everyone,
Thanks.
Geoserver itself is a server sending data when client application wants to get some. Zoom bar you are referring to is not part of Geoserver, it comes from the application. I guess you are seeing some OpenLayers javascript application in your eyes, thus you'd need to have a look on OpenLayers documentation.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Peter Dawn [mailto:petedawn@anonymised.com]
Lähetetty: 13. toukokuuta 2009 7:27
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Hide zoom barHi everyone,
remove/hide the zoom blue bar on the left hand side. I dont
want the user to be able to zoom in or zoom out.Thanks.
The NEW KODAK i700 Series Scanners deliver under ANY
circumstances! Your production scanning environment may not
be a perfect world - but thanks to Kodak, there's a perfect
scanner to get the job done! With the NEW KODAK i700 Series
Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Hi Peter,
I think you meen the PanZoomBar-Control from OpenLayers which is distributed
on the client side thru OpenLayers. The GeoServer doesn't give you any
client side controls.
So I think it is better to ask about this question in the OpenLayers Forum.
And yes there are some possible solutions to prevent the user from zooming.
Best way is if you don't implement any zoom control in OL, but result is
that the user will have only one presented map.
Cheers 2StepForward
Peter Dawn wrote:
Hi everyone,
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
View this message in context: http://www.nabble.com/Hide-zoom-bar-tp23515195p23516589.html
