It is also possible to manipulate the “featuretype.xml” file. For example, open the schema file of top:states from
\geoserver-2.5-RC1\data_dir\workspaces\topp\states_shapefile\states\featuretype.xml
Cut some attribute elements, save the file, restart Geoserver – do
and see what you get.
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi Carlo,
That had occurred to me but for some reason I never bothered testing it (I assumed it didn’t do columns).
That seems to have worked fine; many thanks!
Jonathan
On 19 February 2014 12:32, carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
Jonathan,
you could create an SQL view directly into geoserver:
http://docs.geoserver.org/stable/en/user/data/database/sqlview.html
Carlo
2014-02-19 12:42 GMT+01:00 Jonathan Moules <jonathanmoules@anonymised.com>:
Hi List,
I want to publish a layer but don’t want all of the columns in the database to be visible in the WMS/WFS etc. Is there an easy way to “hide” columns with GeoServer?
(I know I can re-load the data or create a View in the database, but those are both high maintenance).
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
