[Geoserver-users] Hiding labels in raster SLDs
Hi All,
I was wondering if it is possible to hide the labels on a Raster SLD.
Using this as an example (assuming you have a local geoserver with default data running)
http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.wms.web.data.StyleEditPage&name=dem
Is it possible to hide the words "nodata" and "values" in the legend without changing the SLD itself?
I have tried using the "forceLabels" option in the "LEGEND_OPTIONS" but it seems to only work on Polygon/Line/Point Symbolizers.
Just playing around with the SLD, I also tried to change the "type" of the ColorMap entry in accordance with this document.
http://docs.geoserver.org/latest/en/user/styling/sld-reference/rastersymbolizer.html
The way I read it, I should be able to use one of the following and see some sort of difference but I don't see any change in the legend preview. Am I doing something incorrect here?
<ColorMap type="ramp">
<ColorMap type="values">
<ColorMap type="intervals" extended="true">
Thanks
Ben
Build Information
Version
2.6-SNAPSHOT
Git Revision
ef8673baaaad5942a2d14e2e45e6b0a7bf80a3de
Build Date
27-Aug-2014 04:18
GeoTools Version
12-SNAPSHOT (rev fe1cf59a27354b468584a44d20f283f5e8cdc286)
GeoWebCache Version
1.6-SNAPSHOT (rev 899f3cf43aa05a0fcb86e51fae61eb6a23ac92a0/899f3cf43aa05a0fcb86e51fae61eb6a23ac92a0)
Ben Khoo
Gaia Resources
p +61 8 9227 7309
w www.gaiaresources.com.au
e ben.khoo@anonymised.com
