Ciao Samuel,
I do not have clearly understood what you are trying to achieve, could
you please firther clarify?
As far as the ImageMosaic is concerned, it's resolution levels are
used to map the same set of image with differen resolutions.
Of course we can strecth this a bit, especially if you look at the
pyramid reader instead of the mosaic reader. You could then build a
pyramid where each level comprises a mosaic built using a set of
images (even 1 image only) which is completely different from the
other levels, assuming they still covera the same area.
Simone.
On Wed, Apr 23, 2008 at 12:08 AM, SamuelToepke <SToepke@anonymised.com> wrote:
Hello,
I am attempting to get high resolution imagery mosaiced with lower
resolution imagery. For example, 1 GeoTIFF that is high level/low quality
world map, with 1 GeoTIFF that is very fine detail in a certain area, say
over weather formation. I know this is possible using layer groups and
seperate WMS calls, but am attempting to make this work in the ImageMosaic
plugin.
After looking through the mailing lists, the geotools user guide and the
ImageMosaicReader code itself, it does not appear as though GeoServer
supports high resolution imagery in low resolution imagery.
It appears that the resolution levels (in the .properties file) are there
for different internal overviews/pyramid levels. Can anyone confirm or deny
this?
Also, is there a GIS best practice for this type of task? Do people
typically do the layer groups, or have a composite GeoTIFF that's set to the
resolution of the highest resolution piece?
-Sam
View this message in context: http://www.nabble.com/High-Resolution-Imagery-in-Low-Resolution-ImageMosaics-tp16826267p16826267.html
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
