On Fri, Jun 10, 2016 at 5:49 PM, Jelmer van der Linde <
jelmer.van.der.linde@anonymised.com> wrote:
Examples:
http://mirror.ikhoefgeen.nl/geoserver/1.jpg
http://mirror.ikhoefgeen.nl/geoserver/2.jpg
http://mirror.ikhoefgeen.nl/geoserver/3.jpg
They only occur incidentally, not consistently on the same place. The
tiles are cached, but when clearing the cache for that specific layer, they
are regenerated without the same artefacts.
Does anyone have an idea what is happening here?
I believe Simone or Nuno some days ago noticed that the JPEG encoder
selection in
GWC might not be stable across runs, this _could_ explain the issue,
especially if
GeoServer got restarted between the two tiles generations.
I've cc'ed them, they can confirm and see if this could be the cause of
what you're seeing
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
