Hi, How admin the GeoWebCache(GWC)? because my folder “temp” for the images for GWC is expanding, and I don’t now if my folder will occupy all my hard disk, and if this folder will be cleaner by self?
Thanks
Arturo Juárez Lima
Thanks
Arturo Juárez Lima
Arturo Juàrez wrote:
Hi, How admin the GeoWebCache(GWC)? because my folder "temp" for the images for GWC is expanding, and I don't now if my folder will occupy all my hard disk, and if this folder will be cleaner by self?
Thanks
There's currently no support for limiting the total space consumption.
If this is a major concern then the cache should live on a separate partition. Alternatively, you can use a cron job to clean out files that have not been accessed in a while (if your filesystem logs atime, which is quite a performance bottleneck).
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
