[Geoserver-users] How can I change the geofence default admin password?
Using GeoServer 2.7.2.
After setting up a user database with geofence, I can still login at the geofence console with admin/geofence. The admin user I setup has different settings than that. My GF_ schema is in Oracle and from looking at it I’d say this admin account is modeled by the GF_GFUSER table where I see a “Default admin” (FULLNAME) user.
How can I change the password of that user? Am I missing something in the geofence GUI for that? I’m not sure how I would set the password in its properly encoded form. I tried setting the password in GF_GFUSER to that of another account I setup in the GF_GSUSER table but that does not work. Then I can’t login at all. So I put it back like it was.
I’d like to be able to visit the geofence console from outside my firewall with a secure login if possible.
Thanks, Walter Stovall
Hi Walter,
as you noticed, gf_gfuser contains info for the users that can login into
GeoFence, while gf_gsuser contains info about GeoServer users.
There are no facilities on the UI to update the geofence admin pw.
The pw is stored as a MD5 hash in the DB.
In order to change the pw on the DB, you have to create the MD5 of your
choosen pw: i.e
   echo -n YOUR_PASSWORD | md5sum
and then set it into the DB.
   Emanuele
at it I'd say this admin account is modeled by the GF_GFUSER table where I
see a "Default admin" (FULLNAME) user.
geofence GUI for that? I'm not sure how I would set the password in its
Then I can't login at all. So I put it back like it was.
I'd like to be able to visit the geofence console from outside my firewall
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
