[Geoserver-users] How can I remove a layer without going through the management interface?
When I try to remove a layer through the management interface, I am getting a server error and the layer is not removed. After an upgrade, these layers are causing other problems, so how can I remove them without going through the management interface?
Garey Mills
Generate messages about directories that cannot be
read, files that cannot be opened … rather than being silent …
(from man du)
You could try the REST interface. I hesitate to suggest editing the XML, (and then reload config from management interface) but that would be another possibility if REST fails too.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Phil - Thanks for your response. If I was to edit the XML, which files would I edit? I can’t find the layer names that I want to delete anywhere besides in workspaces//
Garey
On Tue, Aug 26, 2014 at 2:05 PM, Phil Scadden <p.scadden@anonymised.com> wrote:
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-users mailing list
(from man du)
Phil - Thanks for your response. If I was to edit the XML, which files would I edit? I can't find the layer names that I want to delete anywhere besides in workspaces/<workplace>/<store>
I have never done this. I also believe it depends on which version of geoserver you use.
I would try doing it by REST first.
  However, what I believe would be enough, would be delete any entry
in data_dir/workspaces/<workspace>/namespace.xml and to delete the directory with the layer name as well. (2.5.1 layout). Definitely want to backup the data_dir first!
And try REST first
