[Geoserver-users] How can I turn off built in GWC?
I would have a try with selecting all layers from the Tile Caching – Tile Layers page and doing “Remove selected cached layers”
-Jukka Rahkonen-
Chris Brown wrote:
We’ve recently switched to using the external GWC. The problem is that we have lots of layers that were created using whilst we were using the internal GWC and they are all still caching tiles even though they aren’t being used.
Is there anyway to stop GWC working for all layers even if they had caching enabled when they were created?
We’re using GeoServer 2.7.2.
W dniu 10.02.2016 o 11:27, Rahkonen Jukka (MML) pisze:
Or try this solution:
https://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg03288.html
I'm not sure if it's "officially supported" by GeoServer team, but it works.
Maciej
The key point when following the step outlined by Just to remove the GWC specific jars is to first stop the container altogether. Then you remove the jars. Otherwise, GeoServer won’t start again. Maybe evident to Java-developers, but it wasn’t to me a few weeks back when I tried the same…
Edward
Date: Wed, 10 Feb 2016 11:46:44 +0100
Subject: Re: [Geoserver-users] How can I turn off built in GWC?
https://www.mail-archive.com/geoserver-users@anonymised.comnet/msg03288.html
I’m not sure if it’s “officially supported” by GeoServer team, but it works.
Maciej
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Geoserver-users@anonymised.comrceforge.net
