[Geoserver-users] How could I block WFS insert/delete transactions based on user group?
Using geoserver 2.7.2 and matching geofence…
We have requirements where some user groups have the ability to execute insert/update transactions and others are limited to update-only.
In the geofence GUI I can configure a rule to block WFS TRANSACTION as a whole. This would be exactly what we need if I could block insert/delete while allowing update.
Can anybody offer insight into how this might be accomplished?
On Thu, Oct 1, 2015 at 2:39 PM, Walter Stovall <walter.stovall@anonymised.com>
There is no way to configure this as of today. The source code is there, so
if you are interested, it can be done (either extending
the security subsystem, or writing a DispatcherCallback, or a
TransactionListener). But yeah, it requires development.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I’m interested in studying the custom programing required for this. If anybody out there knows their way around the geofence code and might comment a bit on how to do this that would be very helpful!
This is what I have in mind functionally…
I’d like to add some methods to the Request pull-down when the user builds/edits a rule. The methods I add to the list are Insert, Update, Delete. Transaction stays in the list and behaves like it does now. But if the user picks Insert for example, the rule will Allow/Deny only if the incoming request is an Insert Transaction.
So at a minimum I would want to modify the GUI to change the picklist. Where would I go to do that?
Then the entries I make there need to be saved into the persistent store for the rules. Is there anything to do there or will that just fall into place because there’s already a place to put a method name and we’re just changing the value stored there?
Then when the rules are tested against incoming geoserver requests, I would need to customize that to recognize that Insert is a subset of Transaction and make that check. What code gets modified to do that?
It would seem that custom geofence code is all that’s required – not geoserver. Is that correct?
Thanks - Walter
On Thu, Oct 1, 2015 at 2:39 PM, Walter Stovall <walter.stovall@…7262…> wrote:
There is no way to configure this as of today. The source code is there, so if you are interested, it can be done (either extending
the security subsystem, or writing a DispatcherCallback, or a TransactionListener). But yeah, it requires development.
Ing. Andrea Aime
@geowolf
Technical Lead
