[Geoserver-users] How do I setup shp file on GeoServer to road poly+road names?
I do not need routing and point of interest.
I just need to display the map with road names can anyone help me out?
I've got multiple shp files but do not know how to link them up.
Tried GeoMerge but couldn't merge them either.
View this message in context: http://www.nabble.com/How-do-I-setup-shp-file-on-GeoServer-to-road-poly%2Broad-names--tp22738872p22738872.html
Basically just add the shapefile to geoserver, tutorial here:
http://geoserver.org/display/GEOSDOC/User+Tutorial+Shapefile
And then set up the SLD style which a simple label. Some info about styling and labbelling here:
http://geoserver.org/display/GEOSDOC/SLD+Intro+Tutorial
http://geoserver.org/display/GEOSDOC/LabelingOptions
I would suggest importing them into PostGIS and then adding the postgis table to geoserver.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
