Hello,
I'm drawing a windbarb layer following Geoserver documentation and examples from GeoSolutions blog. Everything works well except tiled mode - nasty artefacts between adjacent tiles are easily to spot, eg:
Remember to switch mode to "Tiled", zoom to, say 1:2M and pan to 22East, 56North.
If I remember well, user manual states that this can happen in case of mixing tiles with some WPS field functions. Is it possible to use any workaround for that?
Regards
Maciej
P.S. Style definition follows:
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld ./StyledLayerDescriptor.xsd">
<NamedLayer>
<Name>windbarbs</Name>
<UserStyle>
<Title>windbarbs</Title>
<FeatureTypeStyle>
<Transformation>
<ogc:Function name="ras:RasterAsPointCollection">
<ogc:Function name="parameter">
<ogc:Literal>data</ogc:Literal>
</ogc:Function>
<ogc:Literal>interpolation</ogc:Literal>
<ogc:Literal>InterpolationBilinear</ogc:Literal>
</ogc:Function>
<ogc:Literal>scale</ogc:Literal>
<ogc:Function name="Categorize">
<ogc:Function name="env">
<ogc:Literal>wms_scale_denominator</ogc:Literal>
</ogc:Function>
<ogc:Literal>1</ogc:Literal>
<ogc:Literal>1000000</ogc:Literal>
<ogc:Literal>0.6</ogc:Literal>
<ogc:Literal>2000000</ogc:Literal>
<ogc:Literal>0.3</ogc:Literal>
<ogc:Literal>4000000</ogc:Literal>
<ogc:Literal>0.15</ogc:Literal>
<ogc:Literal>8000000</ogc:Literal>
<ogc:Literal>0.075</ogc:Literal>
<ogc:Literal>16000000</ogc:Literal>
<ogc:Literal>0.0375</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</Transformation>
<Rule>
<MaxScaleDenominator>20000000</MaxScaleDenominator>
<PointSymbolizer>
<Graphic>
<Mark>
<WellKnownName>windbarbs://default(
<ogc:Mul>
<ogc:PropertyName>speed</ogc:PropertyName>
</ogc:Mul>
)[m/s]
</WellKnownName>
<Stroke>
<CssParameter name="stroke">000000</CssParameter>
<CssParameter name="stroke-width">1</CssParameter>
</Stroke>
</Mark>
<Size>
<!-- Value to transform -->
<ogc:Literal>6</ogc:Literal>
<ogc:Literal>1.543333332</ogc:Literal>
<ogc:Literal>20</ogc:Literal>
</ogc:Function>
</Size>
<Rotation>
<!-- Output values and thresholds -->
<ogc:Literal>0</ogc:Literal>
<ogc:Add>
<ogc:Literal>180</ogc:Literal>
<ogc:PropertyName>direction</ogc:PropertyName>
</ogc:Add>
</ogc:Function>
</Rotation>
</Graphic>
</PointSymbolizer>
<PointSymbolizer>
<Graphic>
<Mark>
<WellKnownName>circle</WellKnownName>
<Fill>
<CssParameter name="fill">
<ogc:Literal>#ff0000</ogc:Literal>
</CssParameter>
</Fill>
</Mark>
<Size>3</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
