Dear Members,
I am able to publish a layer using Geoserver Rest API using php. However, I couldn’t set the default style. Could you please help me in changing the style?
Thanks!
Dear Members,
Thanks!
Hi Wondimagegn,
it is actually not too difficult: all you have to do is issue a PUT request on the layer, after it has been created.
Sample CURL request:
curl -X PUT -d "<layer><defaultStyle><name>point</name></defaultStyle></layer>" -H "Content-Type: text/xml" -u admin:geoserver http://localhost:8080/geoserver/rest/layers/places.xml
which sets the default style of layer “places” to “point”.
Hope this helps,
–SC
Il giorno gio, 02/07/2015 alle 16.29 +0300, Wondimagegn Tesfaye ha scritto:
Dear Members,
Thanks!
------------------------------------------------------------------------------ Don't Limit Your Business. Reach for the Cloud. GigeNET's Cloud Solutions provide you with the tools and support that you need to offload your IT needs and focus on growing your business. Configured For All Businesses. Start Your Cloud Today. [https://www.gigenetcloud.com/](https://www.gigenetcloud.com/) _______________________________________________ Geoserver-users mailing list [Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net) [https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
<br>-- <br><br>Best regards,<br>Stefano Costa<br><br>==<br>GeoServer Professional Services from the experts! Visit<br>http://goo.gl/it488V for more information.<br>==<br>Dott. Stefano Costa<br>Senior Software Engineer<br><br>GeoSolutions S.A.S.<br>Via Poggio alle Viti 1187<br>55054 Massarosa (LU)<br>Italy<br>phone: +39 0584 962313<br>fax: +39 0584 1660272<br><br>http://www.geo-solutions.it<br>http://twitter.com/geosolutions_it<br><br>-------------------------------------------------------<br>AVVERTENZE AI SENSI DEL D.Lgs. 196/2003<br>Le informazioni contenute in questo messaggio di posta elettronica e/o<br>nel/i file/s allegato/i sono da considerarsi strettamente riservate.<br>Il loro utilizzo è consentito esclusivamente al destinatario del<br>messaggio, per le finalità indicate nel messaggio stesso. Qualora<br>riceviate questo messaggio senza esserne il destinatario, Vi preghiamo<br>cortesemente di darcene notizia via e-mail e di procedere alla<br>distruzione del messaggio stesso, cancellandolo dal Vostro sistema.<br>Conservare il messaggio stesso, divulgarlo anche in parte,<br>distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità<br>diverse, costituisce comportamento contrario ai principi dettati dal<br>D.Lgs. 196/2003.<br><br>The information in this message and/or attachments, is intended solely<br>for the attention and use of the named addressee(s) and may be<br>confidential or proprietary in nature or covered by the provisions of<br>privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New<br>Data Protection Code).Any use not in accord with its purpose, any<br>disclosure, reproduction, copying, distribution, or either<br>dissemination, either whole or partial, is strictly forbidden except<br>previous formal approval of the named addressee(s). If you are not the<br>intended recipient, please contact immediately the sender by<br>telephone, fax or e-mail and delete the information in this message<br>that has been received in error. The sender does not give any warranty<br>or accept liability as the content, accuracy or completeness of sent<br>messages and accepts no responsibility for changes made after they<br>were sent or for other risks which arise as a result of e-mail<br>transmission, viruses, etc.<br><br><br><br> |
On Thu, Jul 2, 2015 at 4:14 PM, Stefano Costa <
stefano.costa@anonymised.com> wrote:
Hi Wondimagegn,
request on the layer, after it has been created.Sample CURL request:
curl -X PUT -d
http://localhost:8080/geoserver/rest/layers/places.xmlwhich sets the default style of layer "places" to "point".
Correct, but always remember to also add <enabled>true</enabled> to the PUT
request to avoid disabling the layer as a side effect
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea,
the PUT request to avoid disabling the layer as a side effect
Uhm... I just tested it against GeoServer 2.7.1 and the layer was not
disabled: may be a bug?
In any case, thanks for your comment, adding <enabled>true</enabled> is
certainly a good practice.
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
On Thu, Jul 2, 2015 at 4:49 PM, Stefano Costa <
Hi Andrea,
> <stefano.costa@anonymised.com> wrote:> Correct, but always remember to also add <enabled>true</enabled> to
Interesting.... nope, disabling any resource/layer/store edited because we
did not
add <enabled>true</enabled> is the bug, not sure how it got fixed though,
thinking
about how XStream persistence/parsing works... basically the code cannot
tell apart the lack of attribute from an explicity "false" because the
attribute is a
primitive.
Just checked, with layer it now works because the enabled field of layer
has been deprecated, and we are just reflecting the one in the resource
associated
to it, which is not being edited in this request.
To avoid this issue in general we should switch all boolean usage for
enabled to
Boolean instead, in stores, resources, and in general everything else in
configuration
that might have a primitive value.
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you for the advice but I was try to use this type of command. http://docs.geoserver.org/stable/en/user/rest/examples/php.html
I also go this class http://www.ibm.com/developerworks/library/os-geoserver/#download
Which works for creating store, workspace, and layers.
The one you posted above is a cmd or terminal command, I guess.
On Thu, Jul 2, 2015 at 5:53 PM, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
On Thu, Jul 2, 2015 at 4:49 PM, Stefano Costa <stefano.costa@anonymised.com7…> wrote:
Hi Andrea,
<stefano.costa@anonymised.com> wrote:Correct, but always remember to also add true to
the PUT request to avoid disabling the layer as a side effectUhm… I just tested it against GeoServer 2.7.1 and the layer was not
Interesting… nope, disabling any resource/layer/store edited because we did not
add true is the bug, not sure how it got fixed though, thinking
about how XStream persistence/parsing works… basically the code cannot
tell apart the lack of attribute from an explicity “false” because the attribute is a
primitive.
has been deprecated, and we are just reflecting the one in the resource associated
To avoid this issue in general we should switch all boolean usage for enabled to
Boolean instead, in stores, resources, and in general everything else in configuration
Ing. Andrea Aime
@geowolf
Technical Lead
I managed to take out the php code from the warpper class but it is still not working. Here is the code.
<?php
$data = '<layer><defaultStyle><name>my_style</name>
<workspace>my_workspace</workspace>
</defaultStyle><enabled>true</enabled></layer>';
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,('[http://192.168.0.89:8080/geoserver/rest/layers/my_workspace:my_style](http://192.168.0.89:8080/geoserver/rest/layers/my_workspace:my_style)') );
curl_setopt($ch, CURLOPT_USERPWD, "admin:geoserver");
curl_setopt($ch, CURLOPT_POST, true);
curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-Type: text/xml", 'Content-Length: '.strlen($data)) );
curl_setopt($ch, CURLOPT_HEADER, false);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_exec($ch);
curl_getinfo($ch);
On Thu, Jul 2, 2015 at 9:09 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
On Thu, Jul 2, 2015 at 5:53 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jul 2, 2015 at 4:49 PM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Hi Andrea,
primitive.
Ing. Andrea Aime
@geowolf
Technical Lead
although I'm no expert on PHP at all, I can see two issues with your
code:
1) looks like you're making a POST, non a PUT request. See
http://www.lornajane.net/posts/2009/putting-data-fields-with-php-curl
for an example.
2) your URL seems wrong: it should be in the form
http://192.168.0.89:8080/geoserver/rest/layers/<layer\_name>\.xml\. Please
review the docs here:
http://docs.geoserver.org/stable/en/user/rest/api/layers.html#layers-l-format
Hope this helps,
--S
Il giorno ven, 03/07/2015 alle 12.01 +0300, Wondimagegn Tesfaye ha
scritto:
still not working. Here is the code.<?php
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,('http://192.168.0.89:8080/geoserver/rest/layers/my_workspace:my_style’) );
curl_exec($ch);
curl_getinfo($ch);
?>On Thu, Jul 2, 2015 at 9:09 PM, Wondimagegn Tesfaye
I also go this
guess.
Hi Andrea,
Costa
as a side effect
"false" because the attribute is a
primitive.
Visit
Ing. Andrea Aime
@geowolf
Technical Lead
elettronica e/o nel/i file/s allegato/i sono da
considerarsi strettamente riservate. Il loro utilizzo
stesso. Qualora riceviate questo messaggio senza
intended solely for the attention and use of the named
addressee(s) and may be confidential or proprietary in
nature or covered by the provisions of privacy act
New Data Protection Code).Any use not in accord with
its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or
partial, is strictly forbidden except previous formal
sender by telephone, fax or e-mail and delete the
error. The sender does not give any warranty or accept
sent messages and accepts no responsibility for
changes made after they were sent or for other risks
which arise as a result of e-mail transmission,
viruses, etc.
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Thank you Stano,
I followed your instruction modified the code but it is still not working.
<?php
$data =[ '<layers><defaultStyle><name>my_style</name>
</defaultStyle><enabled>true</enabled></layers>'];
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,('[http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml](http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml)') );
//curl_setopt($ch, CURLOPT_POST, true);
//curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT");
curl_setopt($ch, CURLOPT_POSTFIELDS,http_build_query($data));
curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-Type: text/xml", 'Content-Length: '.sizeof($data[0])) );
curl_exec($ch);
curl_getinfo($ch);
On this link, at the end of “Changing Layer Style” I see that the url is workspace:layer without xml.
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html#changing-a-layer-style
On Fri, Jul 3, 2015 at 12:16 PM, Stefano Costa <stefano.costa@anonymised.com> wrote:
although I’m no expert on PHP at all, I can see two issues with your
code:
looks like you’re making a POST, non a PUT request. See
for an example.your URL seems wrong: it should be in the form
http://192.168.0.89:8080/geoserver/rest/layers/<layer_name>.xml. Please
http://docs.geoserver.org/stable/en/user/rest/api/layers.html#layers-l-formatHope this helps,
–SIl giorno ven, 03/07/2015 alle 12.01 +0300, Wondimagegn Tesfaye ha
scritto:I managed to take out the php code from the warpper class but it is
<?php $data = 'my_style my_workspace true'; $ch = curl_init(); curl_setopt($ch, CURLOPT_URL,('[http://192.168.0.89:8080/geoserver/rest/layers/my_workspace:my_style](http://192.168.0.89:8080/geoserver/rest/layers/my_workspace:my_style)') ); curl_setopt($ch, CURLOPT_USERPWD, "admin:geoserver"); curl_setopt($ch, CURLOPT_POST, true); curl_setopt($ch, CURLOPT_POSTFIELDS, $data); curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-Type: text/xml", 'Content-Length: '.strlen($data)) ); curl_setopt($ch, CURLOPT_HEADER, false); curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); curl_exec($ch); curl_getinfo($ch); ?>
still not working. Here is the code.On Thu, Jul 2, 2015 at 9:09 PM, Wondimagegn Tesfaye
command. http://docs.geoserver.org/stable/en/user/rest/examples/php.htmlI also go this
class http://www.ibm.com/developerworks/library/os-geoserver/#downloadWhich works for creating store, workspace, and layers.
guess.On Thu, Jul 2, 2015 at 5:53 PM, Andrea Aime
Hi Andrea,Il giorno gio, 02/07/2015 alle 16.32 +0200,
Andrea Aime ha scritto:On Thu, Jul 2, 2015 at 4:14 PM, Stefano
Costa
true to
disabled: may be a bug?Interesting… nope, disabling any
primitive.Just checked, with layer it now works because the
to it, which is not being edited in this request.To avoid this issue in general we should switch all
that might have a primitive value.Cheers
Andrea–
Visit
http://goo.gl/it488V for more information.Ing. Andrea Aime
@anonymised.com
Technical LeadGeoSolutions S.A.S.
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_itAVVERTENZE AI SENSI DEL D.Lgs. 196/2003
principi dettati dal D.Lgs. 196/2003.The information in this message and/or attachments, is
(Legislative Decree June, 30 2003, no.196 - Italy’s
viruses, etc.
Best regards,
Stefano Costa==
http://goo.gl/it488V for more information.Dott. Stefano Costa
Senior Software EngineerGeoSolutions S.A.S.
fax: +39 0584 1660272http://www.geo-solutions.it
D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
To be clearer on what I want to achieve, I have already created the style and I just want to replace the default “Polygon” style with “my_style”.
On Fri, Jul 3, 2015 at 12:36 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
Thank you Stano,
<?php $data =[ '<layers><defaultStyle><name>my_style</name> <workspace>my_workspace</workspace> </defaultStyle><enabled>true</enabled></layers>']; $ch = curl_init(); curl_setopt($ch, CURLOPT_URL,('[http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml](http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml)') ); curl_setopt($ch, CURLOPT_USERPWD, "admin:geoserver"); //curl_setopt($ch, CURLOPT_POST, true); //curl_setopt($ch, CURLOPT_POSTFIELDS, $data); curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT"); curl_setopt($ch, CURLOPT_POSTFIELDS,http_build_query($data)); curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-Type: text/xml", 'Content-Length: '.sizeof($data[0])) ); curl_setopt($ch, CURLOPT_HEADER, false); curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); curl_exec($ch); curl_getinfo($ch); ?>
code:
Costa
true to
Andrea–
Visit
@anonymised.com
viruses, etc.
Best regards,
Stefano Costa==
could you please share the error you get from the server?
Other things you could try:
1) don't set 'Content-Length' header I don't think it's necessary
2) comment line "curl_setopt($ch, CURLOPT_HEADER, false);"
3) don't wrap $data into a call to http_build_query(), just use it as it
is
Let us know if you manage to get it to work.
--S
Il giorno ven, 03/07/2015 alle 12.36 +0300, Wondimagegn Tesfaye ha
scritto:
Thank you Stano,
working.<?php
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,('http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml’) );
//curl_setopt($ch, CURLOPT_POSTFIELDS, $data);curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT");
curl_exec($ch);
curl_getinfo($ch);
?>On this link, at the end of "Changing Layer Style" I see that the url
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Hello Stefano,
I again tried with your suggestion but it is not working still. Below is the log.
2015-07-03 15:06:57,451 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1 “GET /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000” took 71ms
2015-07-03 15:07:16,319 INFO [geoserver.filters] - 192.168.0.89 “PUT /geoserver/rest/layers/vahk7spti86tggnl1ib0u98kou7_e27_s16_a57.xml” “” “” request-size: 183 body:
custom_vulnerability_index
user_vulnerability_index
true
2015-07-03 15:07:16,325 ERROR [geoserver.rest] -
com.thoughtworks.xstream.mapper.CannotResolveClassException: layers
at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:79)
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:30)
at com.thoughtworks.xstream.mapper.DynamicProxyMapper.realClass(DynamicProxyMapper.java:55)
at com.thoughtworks.xstream.mapper.PackageAliasingMapper.realClass(PackageAliasingMapper.java:88)
at com.thoughtworks.xstream.mapper.ClassAliasingMapper.realClass(ClassAliasingMapper.java:79)
at com.thoughtworks.xstream.mapper.ArrayMapper.realClass(ArrayMapper.java:74)
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:71)
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:133)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1185)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1169)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1049)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:577)
at org.geoserver.catalog.rest.AbstractCatalogResource$1.read(AbstractCatalogResource.java:51)
at org.geoserver.rest.format.StreamDataFormat.toObject(StreamDataFormat.java:34)
at org.geoserver.rest.ReflectiveResource.handlePut(ReflectiveResource.java:192)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:800)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:730)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:82)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
2015-07-03 15:07:16,413 INFO [geoserver.filters] - 192.168.0.89 “PUT /geoserver/rest/layers/vahk7spti86tggnl1ib0u98kou7_e27_s16_a57.xml” took 94ms
2015-07-03 15:07:20,231 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1 “POST /geoserver/web/?wicket:interface=:45:form::IFormSubmitListener::” “Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36” “http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000” request-size: 20 body:
refresh=x&lines=1000
2015-07-03 15:07:20,236 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1 “POST /geoserver/web/?wicket:interface=:45:form::IFormSubmitListener::” took 5ms
2015-07-03 15:07:20,242 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1 “GET /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000” “Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36” “http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000”
On Fri, Jul 3, 2015 at 2:50 PM, Stefano Costa <stefano.costa@anonymised.com> wrote:
could you please share the error you get from the server?Other things you could try:
- don’t set ‘Content-Length’ header I don’t think it’s necessary
- comment line “curl_setopt($ch, CURLOPT_HEADER, false);”
- don’t wrap $data into a call to http_build_query(), just use it as it
isLet us know if you manage to get it to work.
–S
scritto:Thank you Stano,
<?php $data =[ 'my_style my_workspace true']; $ch = curl_init(); curl_setopt($ch, CURLOPT_URL,('[http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml](http://192.168.0.9:8080/geoserver/rest/layers/my_layer.xml)') ); curl_setopt($ch, CURLOPT_USERPWD, "admin:geoserver"); //curl_setopt($ch, CURLOPT_POST, true); //curl_setopt($ch, CURLOPT_POSTFIELDS, $data); curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT"); curl_setopt($ch, CURLOPT_POSTFIELDS,http_build_query($data)); curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-Type: text/xml", 'Content-Length: '.sizeof($data[0])) ); curl_setopt($ch, CURLOPT_HEADER, false); curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); curl_exec($ch); curl_getinfo($ch); ?>
working.On this link, at the end of “Changing Layer Style” I see that the url
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html#changing-a-layer-style–
Best regards,
Stefano Costa==
Hi again,
yes, now I see you have <layers> instad of <layer> in your XML (no final
's')... that's for sure a problem.
--S
Il giorno ven, 03/07/2015 alle 15.10 +0300, Wondimagegn Tesfaye ha
scritto:
Hello Stefano,
is the log.2015-07-03 15:06:57,451 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1
"GET /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000" took 71ms
"PUT /geoserver/rest/layers/vahk7spti86tggnl1ib0u98kou7_e27_s16_a57.xml" "" "" request-size: 183 body:
<layers><defaultStyle><name>custom_vulnerability_index</name>
<workspace>user_vulnerability_index</workspace>
</defaultStyle><enabled>true</enabled></layers>2015-07-03 15:07:16,325 ERROR [geoserver.rest] -
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
"PUT /geoserver/rest/layers/vahk7spti86tggnl1ib0u98kou7_e27_s16_a57.xml" took 94ms
"POST /geoserver/web/?wicket:interface=:45:form::IFormSubmitListener::" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36" "http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000" request-size: 20 body:
refresh=x&lines=10002015-07-03 15:07:20,236 INFO [geoserver.filters] - 0:0:0:0:0:0:0:1
"POST /geoserver/web/?wicket:interface=:45:form::IFormSubmitListener::" took 5ms
"GET /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36" "http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000"
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Thank you very much Stefano. It works now!! I am glad but there are two more issues.
One is, the layer loads very very slowly as compared to the one that loads with the default Polygon style or another layer that I manually set the style for.
The other issue is the layer only shows when zoomed in one step and further.
On Fri, Jul 3, 2015 at 3:15 PM, Stefano Costa <stefano.costa@anonymised.com1107…> wrote:
Hi again,
yes, now I see you have instad of in your XML (no final
‘s’)… that’s for sure a problem.–S
scritto:Hello Stefano,
true2015-07-03 15:07:16,325 ERROR [geoserver.rest] -
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
“GET /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000” “Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36” “http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.admin.LogPage&lines=1000”–
Best regards,
Stefano Costa==
I got a solution for the problem of slow loading. There were over 88,000 rows in postgres table and the sld style had to create range for the values. So I did the categorization in the table and now it works as fast as I want.
The only issue remaining is the disappearance of the layer on default zoom and appearance on zoom in.
On Fri, Jul 3, 2015 at 3:29 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
On Fri, Jul 3, 2015 at 3:15 PM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Hi again,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best regards,
Stefano Costa==
The layers are generated by rest api are now working well after I enabled prepared statements. Everything is working as expected.
On Fri, Jul 3, 2015 at 11:36 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
On Fri, Jul 3, 2015 at 3:29 PM, Wondimagegn Tesfaye <wondim81@anonymised.com4…> wrote:
On Fri, Jul 3, 2015 at 3:15 PM, Stefano Costa <stefano.costa@anonymised.com7…> wrote:
Hi again,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best regards,
Stefano Costa==
Thanks, Wondimagegn, for reporting back on how you solved the problem.
Perhaps next time you find other unrelated issues while solving the one
under discussion, you should start a separate thread, to better isolate
topics and facilitate searching the mailing list archives.
Stefano
Hi again,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best regards,
Stefano Costa==
fax: +39 0584 1660272> http://www.geo-solutions.it
You are welcome and thank you for the help too Stefano, I will correct the mistake in the future.
On Wed, Jul 8, 2015 at 1:41 PM, stefano.costa <stefano.costa@anonymised.com> wrote:
topics and facilitate searching the mailing list archives.Cheers,
StefanoDa: “Wondimagegn Tesfaye” wondim81@anonymised.com
A: “Stefano Costa” stefano.costa@anonymised.com
Cc: “Andrea Aime” andrea.aime@anonymised.com,“geoserver-users” Geoserver-users@lists.sourceforge.net
Data: Mon, 6 Jul 2015 21:46:38 +0300
Oggetto: Re: [Geoserver-users] How to change the default style of a layer?The layers are generated by rest api are now working well after I enabled prepared statements. Everything is working as expected.
Hi again,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best regards,
Stefano Costa==
