Very good suggestion. I did set a default value and was able to save the layer based on the SQL view that has this query
SELECT *, %myheight% as height from mytable
The kml that I can get from the preview works too.’
Now when i try to use the variable %myheight% like in this string in the kml file
http://myurl:8080/geoserver/drive/wms?service=wms&viewparams= myheight:revenue__million&request=GetMap&version=1.1.1&format=application/vnd.google-earth.kml+xml&layers=drive:mytable&styles=point&height=2048&width=2048&transparent=false&srs=EPSG:4326&format_options=SUPEROVERLAY:false;AUTOFIT:true;KMPLACEMARK:false;KMSCORE:80;KMATTR:true;MODE:refresh
it does not work any more and I get the following error in the GeoServer log:
I also see that the following parameter gets send out (one can see that the MYHEIGHT actually is used as parameter ):
ViewParams = [{MYHEIGHT=revenue__million}]
This is the GeoServer error message :
WARN [geotools.jdbc] - Failed to use ST_Estimated_Extent, falling back on envelope aggregation
org.postgresql.util.PSQLException: ERROR: relation “mytable” does not exist
Where: SQL statement “SELECT has_table_privilege((SELECT usesysid FROM pg_user WHERE usename = session_user), ‘“tmp”.“kc_comp_query”’, ‘select’)”
Any ideas why geotools fails to get the extent ?
Karsten
: Re: [Geoserver-users] how to create a totally dynamic GeoServer layer - and dynamic heights in KML output ?
Maybe you have to set a valid default value in the sql view parameters table below the view (one existing column) to allow geoserver to validate the query and check the type of the attribute.
For instance, if your table has the following columns:
gid,value1, value2, the_geom
try to set value1 as default value and try to save.
Check the geoserver log if you have errors to see the generated query and why it fails.
