Hello ,
I try this tutorial http://geoserver.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data but it’s doesnt work.
Can you help me and tell me how to generate a raster pyramid with geoserver.
Thanks and sorry for my English :s
Jim
Hello ,
Jim
if you want to put your images in a database, look here
http://docs.geoserver.org/1.7.x/user/tutorials/imagemosaic-jdbc/imagemosaic- jdbc_tutorial.html
Jimmy Aumard writes:
Hello ,
I try this tutorial
http://geoserver.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data but it's
doesnt work.Can you help me and tell me how to generate a raster pyramid with geoserver.
Jim
Thanks Christian,
I have geoserver 1.7.5 and I have Image Mozaic plugin but not the Image Mosaicing Pyramidal JDBC Plugin, it’s the same? Where find it?
I have another little question: It’s possible to put raster file on postgis?
Jim
2009/6/4 Christian Müller <christian.mueller@anonymised.com>
http://docs.geoserver.org/1.7.x/user/tutorials/imagemosaic-jdbc/imagemosaic- jdbc_tutorial.htmlJimmy Aumard writes:
Hello ,
I try this tutorial
doesnt work.
Jim
Hi Jim
2009/6/5 Jimmy Aumard <jimmy.aumard@anonymised.com>:
Thanks Christian,
Mosaicing Pyramidal JDBC Plugin, it's the same? Where find it?
You can find it in the file geotools-2.5.5-bin.zip.
http://geotools.codehaus.org/Downloads
Aftre extract the file,
you will find the file gt-imagemosaic-jdbc-2.5.5.jar.
copy that file to the directory /webapps/geoserver/WEB-INF/lib.
I have another little question: It's possible to put raster file on postgis?
It is possible.
I'd try it yesterday.
Jim
jdbc_tutorial.html
Jimmy Aumard writes:Hello ,
I try this tutorial
doesnt work.
geoserver.
Jim
Yoichi Kayama ha scritto:
Hi Jim
Thanks Christian,
Mosaicing Pyramidal JDBC Plugin, it's the same? Where find it?You can find it in the file geotools-2.5.5-bin.zip.
You can also get it as part of the official GeoServer extensions here:
http://geoserver.org/display/GEOS/Stable
Andrea Aime
OpenGeo - http://opengeo.org
Additional info:
Yes, you can use postgis, you can even use postgres without postgis (Universal Driver), for supported systems look here
http://docs.codehaus.org/display/GEOTDOC/Image+Mosaicing+Pyramidal+JDBC+Plug in
Thanks Christian,
Plugin<http://docs.codehaus.org/display/GEOTDOC/Image+Mosaicing+Pyramidal+JDBC+Plugin>,
it's the same? Where find it?I have another little question: It's possible to put raster file on postgis?
Jim
http://docs.geoserver.org/1.7.x/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html
I try this tutorial
doesnt work.
geoserver.
Jim
