Hello everybody
What command-line tool may I use to get the metadata (bound coords, area
covered...) of a SHP or a TAB file?
Thanks a lot in advance
Hello everybody
Try ogrinfo, it comes for example with extremely useful FWTools package from fwtools.maptools.org.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Jorge [mailto:jorge.arevalo@anonymised.com]
Lähetetty: ke 7.1.2009 18:05
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] How to get metadata of a SHP file
Hello everybody
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Hi Jukka
In fact, I'm using ogrinfo, but I can't find the correct parameters.
Other tools, like Global Mapper, show this info, but I need a
command-line tool.
Thanks anyway
Rahkonen Jukka escribió:
-Jukka Rahkonen-
Aihe: [Geoserver-users] How to get metadata of a SHP fileHello everybody
covered...) of a SHP or a TAB file?Thanks a lot in advance
"Afirmo con total convicción que la religión cristiana organizada como Iglesia ha sido y es aún la principal enemiga del progreso moral en el mundo"
"La religión se basa, pienso, principal y primariamente en el miedo. El miedo es el padre de la crueldad, y por tanto no es sorprendente que crueldad y religión han ido tomadas de la mano. La ciencia puede ayudarnos a superar este cobarde temor en que ha vivido la humanidad por tantas generaciones."
(Bertrand Russell)
Is it anything else than a command line tool? Anyway, for getting basic info about shapefile do:
C:\data>ogrinfo -summary temp.shp temp
INFO: Open of `temp.shp'
using driver `ESRI Shapefile' successful.
Layer name: temp
Geometry: Polygon
Feature Count: 18
Extent: (3385998.357693, 6676168.437985) - (3386517.531951, 6676554.808779)
Layer SRS WKT:
PROJCS["Transverse_Mercator",
GEOGCS["International 1909 (Hayford)",
DATUM["unknown",
SPHEROID["intl",6378388,297]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",27],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",3500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
-Jukka Rahkonen-
Lähetetty: ke 7.1.2009 19:06
Vastaanottaja: Rahkonen Jukka
Kopio: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] How to get metadata of a SHP file
Hi Jukka
command-line tool.
Thanks anyway
-Jukka Rahkonen-
(Bertrand Russell)
Thanks for the info! I forgot the name of the layer after the name of the shapefile. I feel stupid…
Long life to command line tools!
Regards
Jorge
(Bertrand Russell)
hey,
have you tried ogrinfo that comes with FWTools / GDAL ?
-i
2009/1/7 Jorge <jorge.arevalo@anonymised.com>:
Hello everybody
oops sorry. still getting used to gmail style email
2009/1/8 Ivan Price <gunn.point@anonymised.com>:
hey,
-i
Hello everybody
