Dear Team,
I would like to share data on geoserver using an application. In doing so, I wanted to show the file size. Is there a way to access the output files such as shp zip, tiff etc or get their details through Rest API?
Thank you!
Dear Team,
Thank you!
On Sat, Jul 11, 2015 at 7:51 AM, Wondimagegn Tesfaye <wondim81@anonymised.com>
wrote:
Dear Team,
Nope. All WFS/WCS/WMS outputs are dynamically generated anyways, we never
return the original file (there is however a planned CSW extension to allow
linking back to the original data for raw download).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
That is promising. Will the CSW extension allow download of postgis store too?
On Sat, Jul 11, 2015 at 3:36 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Jul 11, 2015 at 7:51 AM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
Dear Team,
Nope. All WFS/WCS/WMS outputs are dynamically generated anyways, we never return the original file (there is however a planned CSW extension to allow linking back to the original data for raw download).
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Jul 11, 2015 at 4:58 PM, Wondimagegn Tesfaye <wondim81@anonymised.com>
too?
No, only file based sources, exactly as they are on disk.
There is no such a thing for database based sources (well, one could argue
that a database dump would get close, but
it is not part of the targeted funding we have for this feature).
Ing. Andrea Aime
@geowolf
Technical Lead
That is understandable.
Thank you!
On Sat, Jul 11, 2015 at 7:47 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Jul 11, 2015 at 4:58 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
