[Geoserver-users] How to give rights to one layer from secured workspace?
I have a workspace with restricted access:
hasici.*.r=ROLE_HASICI
hasici.*.w=ROLE_HASICI
hasici.*.a=ROLE_HASICI
And I have one layer in the workspace, that should be accessible to more people then the others:
hasici.pest.r=ROLE_HASICI,ROLE_PEST
Then I have a user, who does have ROLE_PEST assigned, and does not have the ROLE_HASICI assigned. I assume he should be able to see the layer pest. He logs into geoserver web, and he can see the layer 'hasici:pest' in the 'Layer Preview' list as expected. But when he clicks the 'OpenLayers' link, 404 is shown. The layer can be seen by the users who have the ROLE_HASICI assigned.
Am I missing something? How this should be configured?
Thank you very much for your advice,
Michal
layer_preview.log (3.64 KB)
Hi Michal,
I’m not really involved in the geoserver security module, but I think the problem could be in some conflict between “layer security” and “service security”: if I’m not wrong “layer preview” use WMS service.
http://docs.geoserver.org/2.3.2/user/security/layer.html
ciao
Michele
On Wed, Jul 3, 2013 at 7:03 PM, <sredl@anonymised.com> wrote:
hasici..r=ROLE_HASICI
hasici.
.w=ROLE_HASICI
Then I have a user, who does have ROLE_PEST assigned, and does not have the ROLE_HASICI assigned. I assume he should be able to see the layer pest. He logs into geoserver web, and he can see the layer ‘hasici:pest’ in the ‘Layer Preview’ list as expected. But when he clicks the ‘OpenLayers’ link, 404 is shown. The layer can be seen by the users who have the ROLE_HASICI assigned.
Michal
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
Hi Michele,
thank you for your answer. No, I am not using service security at all. Of course I do ask for the layer through OWS (and that is what I want to do in the map application as well), but I don't use the service security to configure it. The file service.properties is present, but contains comments only.
The think is, when I try to restrict the access to one particular layer more, (only to people who have the access to the whole ws and have some additional rights) it works, but when I try to give the access to one particular layer to more people, who don't have rights to the whole ws, it fails. The layer is shown in the available preview list, but 404 is returned.
Kind regards,
Michal
Dne 04.07.2013 09:12, Michele Beneventi napsal:
Hi Michal,
I'm not really involved in the geoserver security module, but I think
the problem could be in some conflict between "layer security" and
"service security": if I'm not wrong "layer preview" use WMS service.
http://docs.geoserver.org/2.3.2/user/security/layer.html [3]
ciao
Michele
Michal
http://p.sf.net/sfu/windows-dev2dev [1]
https://lists.sourceforge.net/lists/listinfo/geoserver-users [2]
Links:
[1] http://p.sf.net/sfu/windows-dev2dev
[2] https://lists.sourceforge.net/lists/listinfo/geoserver-users
[3] http://docs.geoserver.org/2.3.2/user/security/layer.html
the only way I see that works is to unsecure the whole workspace and secure every layer instead:
#hasici.*.r=ROLE_HASICI
#hasici.*.w=ROLE_HASICI
hasici.pest.r=ROLE_HASICI, ROLE_PEST
hasici.pest.w=ROLE_HASICI
hasici.chemicals.r=ROLE_HASICI
hasici.chemicals.w=ROLE_HASICI
This way I can secure all the layers of the workspace and meanwhile give the access rights to one layer to more people. I don't like it very much though, as it adds a lot of config lines and also, if accidentally one layer of the workspace is forgotten, it is left unsecured.
Is this the only solution that should work? If I uncomment the first two lines and secure the workspace, then a user with the ROLE_PEST and without the ROLE_HASICI gets 404 when requesting the layer...
Using GeoServer 2.3.2.
Kind regards,
Michal
Dne 04.07.2013 10:03, sredl@anonymised.com napsal:
Hi Michele,
comments only.
returned.
Kind regards,
Michal
Hi Michal,
ciao
Michele
Michal
Links:
the following configuration does not allow a user with ROLE_2 only to read the layer1 from workspace ws:
  ws.*.r=ROLE_1
  ws.*.w=ROLE_1
  ws.*.a=ROLE_1
  ws.layer1.r=ROLE_1,ROLE_2
Is it a bug or is it an expected behaviour?
Kind regards,
Michal
Dne 04.07.2013 17:56, sredl@anonymised.com napsal:
unsecured.
Kind regards,
Michal
Hi Michele,
comments only.
returned.
Kind regards,
Michal
Hi Michal,
ciao
Michele
Michal
Links:
Hi Michal,
I don’t know answer about your question but I tried the following:
On Tue, Jul 9, 2013 at 11:12 AM, <sredl@anonymised.com> wrote:
ws..r=ROLE_1
ws.
.w=ROLE_1
ws.*.a=ROLE_1
Kind regards,
Michal
#hasici..r=ROLE_HASICI
#hasici.
.w=ROLE_HASICI
give the access rights to one layer to more people. I don’t like it
unsecured.
and
without the ROLE_HASICI gets 404 when requesting the layer…
Kind regards,
Michal
Dne 04.07.2013 10:03, sredl@anonymised.com0… napsal:
Hi Michele,
all.
want to
do in the map application as well), but I don’t use the service
security
contains
comments only.
layer
some
one
particular layer to more people, who don’t have rights to the whole
ws,
is
returned.
Kind regards,
Michal
Hi Michal,
think
service.
ciao
Michele
hasici.
.w=ROLE_HASICI
to
the
by
Michal
Links:
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Hi Michelle, all, yes and no:
Yes, thanks a lot, the suggested workaround works, switching the catalogue mode to "challenge" helps.
No, this workaround is unfortunately not suitable. We use the "hide" mode. We need to hide the layers that the user does not have access to from the capabilities document, it would create a mess in our map client.
Should I lodge a bug?
To repeat shortly the story:
The layer1 is secured:
ws.layer1.r=ROLE_READ_L1
but cannot be seen by user who DOES HAVE the ROLE_READ_L1 if
   ws.*.r=OTHER _ROLE
or
   *.*.r=OTHER_ROLE
is set.
It does appear in the LayerPreview list, but requesting the map results in 404.
GeoServer 2.3.2 and 2.3.3. Log attached.
Kind Regards,
Michal
Dne 2013-07-09 11:55, Michele Beneventi napsal:
Hi Michal,
I don't know answer about your question but I tried the following:
ws.*.r=ROLE_1
ws.*.w=ROLE_1
ws.*.a=ROLE_1
ws.layer1.r=ROLE_2
with catalogue mode turned to "challenge"
as a result I got that ROLE_2 can see all the catalogues layers, but
it can access (Read) only layer1.
could it be a workaround?
Regards
Michele
to
ws.*.r=ROLE_1
ws.*.w=ROLE_1
ws.*.a=ROLE_1
Kind regards,
Michal
and
meanwhile
it
unsecured.
first
ROLE_PEST
and
Kind regards,
Michal
Hi Michele,
at
all.
want to
security
contains
comments only.
particular
layer
have
some
to
one
whole
ws,
404
is
returned.
Kind regards,
Michal
Hi Michal,
think
and
service.
http://docs.geoserver.org/2.3.2/user/security/layer.html [1]
[3]
ciao
Michele
accessible
to
not
see
the
layer
when he
seen
by
Michal
http://p.sf.net/sfu/windows-dev2dev [2] [1]
[3] [2]
Links:
[1] http://p.sf.net/sfu/windows-dev2dev [2]
[2]
https://lists.sourceforge.net/lists/listinfo/geoserver-users [3]
[1]
AppDynamics
[4]
Links:
[1] http://docs.geoserver.org/2.3.2/user/security/layer.html
[2] http://p.sf.net/sfu/windows-dev2dev
[3] https://lists.sourceforge.net/lists/listinfo/geoserver-users
[4]
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&amp;iu=/4140/ostg.clktrk
security log (3.75 KB)
