Hello everybody,
I want to know if it’s possible to have the response of a wms getFeatureInfo request in xml and if it’s possible to make the same request but for more than one layer.
I try INFO_FORMAT=text/xml but that doesn’t work.
Thanks
Jim
Hello everybody,
Thanks
Jim
try
application/vnd.ogc.gml
Yes you can have more than 1 query layer.
Best regards,
Bart
Hello everybody,
I want to know if it's possible to have the response of a wms
getFeatureInfo
request in xml and if it's possible to make the same request but for more
than one layer.I try INFO_FORMAT=text/xml but that doesn't work.
Thanks
Jim
Geoserver-users mailing list
Thanks Bart,
It’s possible to have just attributes same as text/html or text/plain because application/vnd.ogc.gml give me geometry’s too and if my layer is big it’s a quit long.
Jim
2009/6/24 <bartvde@anonymised.com>
try
Best regards,
BartHello everybody,
getFeatureInfo
than one layer.I try INFO_FORMAT=text/xml but that doesn’t work.
Thanks
Jim
Unfortunately not, there is no way to limit the attributes with GML output, only HTML output.
The only way to limit the attributes would have to be done at the data level, either via a view, or using a custom schema.xsd file in a feature type directory which removes some of the attributes. But these changes would propagate everywhere, not just the result of GetFeatureInfo
-Justin
Jimmy Aumard wrote:
Thanks Bart,
It's possible to have just attributes same as text/html or text/plain because application/vnd.ogc.gml give me geometry's too and if my layer is big it's a quit long.
Jim
2009/6/24 <bartvde@anonymised.com <mailto:bartvde@anonymised.com>>
try
Best regards,
Bart> Hello everybody,
> getFeatureInfo
for more
> than one layer.
> Thanks
> Jim
> Geoserver-users@lists.sourceforge.net
<mailto:Geoserver-users@lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
OpenGeo - http://opengeo.org
