Hi All,
I want to import shapefile to PostGIS, but the shapefile have many columns and I want to import only column geom.
The code below makes the importation of all columns of the Shapefile, how do you import only the geom column?
Map params = new HashMap();
params.put("dbtype", "postgis"); //must be postgis
params.put("host", ConstantesMd.BD_HOST); //the name or ip address of the machine running PostGIS
params.put("port", new Integer(5432)); //the port that PostGIS is running on (generally 5432)
params.put("database", ConstantesMd.BD_NOME); //the name of the database to connect to.
params.put("user", ConstantesMd.BD_USUARIO); //the user to connect with
params.put("passwd", ConstantesMd.BD_SENHA);
params.put("schema", lNomSchema);
PostgisDataStore pgDatastore = (PostgisDataStore)DataStoreFinder.getDataStore(params);
PostgisFeatureStore fsBC = (PostgisFeatureStore)pgDatastore.getFeatureSource(lNomTabela);
Feature ftc = new Feature[1];
for (FeatureIterator it=source.getFeatures().features(); it.hasNext(); ) {
try {
ftc[0] = (Feature)it.next();
FeatureReader feature = DataUtilities.reader(ftc);
fsBC.addFeatures(feature);
lIntLinhasImportadas++;
System.out.println("Linha: " + lIntLinhasImportadas);
} catch (Exception e) {
e.printStackTrace();
System.out.println( e.getMessage() );
lIntTotalLinhas++;
Best Regards,
Fernando Quadro
GeoServer-BR
http://www.fernandoquadro.com.br
twitter.com/fernandoquadro
Hi Fernando,
What I would try is first querying the shapefile datastore with a query that specifies only the attributes you want to import into the database. Example:
String properties = new String{"prop1","prop2",...};
Query query = new DefaultQuery( "theTypeName", Filter.INCLUDE, properties);
FeatureCollection features = source.getFeatures(query);
-Justin
Fernando Quadro wrote:
Hi All,
try { ftc[0] = (Feature)it.next(); FeatureReader feature = DataUtilities.reader(ftc); fsBC.addFeatures(feature);
lIntTotalLinhas++; }
Best Regards,
Fernando Quadro
GeoServer-BR
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
