Of course, excuse me!
I use GeoServer 1.6.0-RC2 with the corresponding vpf Extension
and GeoServer 1.5.3 also with the corresponding vpf Extension. Both under
Windows XP.
I use the GeoServer 1.5.3 version under Suse Linux Enterprise Server 10.
In the Geoserver I press on DataStores->new->and use Vector Format Product
Library.
In the following window I use the URL to the LHT file of my Vmap
(file:data/vmap/v0noa/vmaplv0/noamer).
After pushing submit, the message: "unable to connect ..." appears.
In the logfile of the console comes "form connection params {
url=file:data/vmap/v0noa/vmaplv0/noamer}".
But I found no Exception, Error or Warning.
There isn't much information, but that's also a part of my problem.
At least the Windows XP GeoServer 1.6.0 console log:
GEOSERVER_HOME environment variable not found. Using current
directory. Please set GEOSERVER_HOME for future uses.
0 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com vi
a org.mortbay.log.Slf4jLog
453 [main] INFO org.mortbay.log - jetty-6.0.2
5523 [main] INFO /geoserver - Loading Spring root WebApplicationContext
20 Dez 08:45:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: D:\Programme\GeoServer1.6.0RC1\.\data_dir
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
20 Dez 08:45:56 INFO [geoserver.global] - StdOut logging enabled. Log file
also
output to 'D:\Programme\GeoServer1.6.0RC1\.\data_dir\logs\geoserver.log'
20 Dez 08:45:57 INFO [geoserver.global] - Loading feature type
'DS_giant_polygon
:::giant_polygon' (layer 1/14)
'DS_poi:::poi' (l
ayer 2/14)
'DS_poly_landmark
s:::poly_landmarks' (layer 3/14)
'DS_tiger_roads::
:tiger_roads' (layer 4/14)
'sfArchsites:::ar
chsites' (layer 5/14)
'sfBugsites:::bug
sites' (layer 6/14)
'sfRestricted:::r
estricted' (layer 7/14)
'sfRoads:::roads'
(layer 8/14)
'sfStreams:::stre
ams' (layer 9/14)
'states_shapefile
:::states' (layer 10/14)
'tasmania_cities:
::tasmania_cities' (layer 11/14)
'tasmania_roads::
:tasmania_roads' (layer 12/14)
'tasmania_state_b
oundaries:::tasmania_state_boundaries' (layer 13/14)
'tasmania_water_b
odies:::tasmania_water_bodies' (layer 14/14)
16805 [main] INFO /geoserver - Initializing WebApplicationContext for Struts
Act
ionServlet 'action', module ''
16977 [main] INFO org.mortbay.log - Started SelectChannelConnector @
0.0.0.0:808
0
31591 [btpool0-6] ERROR org.mortbay.log -
/geoserver/config/data/storeSubmit.do:
java.lang.RuntimeException: selectedDataStoreId required in Session
at
org.vfny.geoserver.form.data.DataDataStoresEditorForm.reset(DataDataS
toresEditorForm.java:114)
at
org.apache.struts.action.RequestProcessor.processPopulate(RequestProc
essor.java:809)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.ja
va:203)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:119
6)
at
org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
Handler.java:1054)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(F
ilterChainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Filt
erSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Fi
lterSecurityInterceptor.java:72)
at
ilterChainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTra
nslationFilter.java:110)
at
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFil
ter(AnonymousProcessingFilter.java:125)
at
at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(R
ememberMeProcessingFilter.java:142)
at
at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doF
ilter(SecurityContextHolderAwareRequestFilter.java:81)
at
at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProces
singFilter.java:217)
at
at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:1
06)
at
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilte
r(HttpSessionContextIntegrationFilter.java:229)
at
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.jav
a:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.j
ava:98)
at
Handler.java:1045)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCha
racterEncodingFilter.java:108)
at
Handler.java:1045)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:3
58)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:2
31)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:6
29)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHand
lerCollection.java:149)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.
java:123)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:1
41)
at org.mortbay.jetty.Server.handle(Server.java:303)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:45
2)
at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpCo
nnection.java:721)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.ja
va:320)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool
.java:475)
at
at
essor.java:809)
at
va:203)
at
6)
at
at
at
Handler.java:1054)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
06)
at
at
at
at
a:148)
at
ava:98)
at
Handler.java:1045)
at
at
Handler.java:1045)
at
58)
at
31)
at
29)
at
at
at
java:123)
at
41)
at
2)
at
nnection.java:721)
at
va:320)
at
.java:475)
form connection params { url=file:data/vmap/v0noa/vmaplv0/noamer}
and console output from the Linux version:
GEOSERVER DATA DIR is /home/geoserver/geoserver/data_dir
1 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com
via org.mortbay.log.Slf4jLog
519 [main] INFO org.mortbay.log - jetty-6.0.1
2313 [main] INFO org.springframework.web.context.ContextLoader - Root
WebApplica tionContext: initialization started
2313 [main] INFO /geoserver - Loading Spring root WebApplicationContext
2416 [main] INFO
org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML
bean definitions from URL [jar:file:/home/geoserver/geoserver/webap
ps/geoserver/WEB-INF/lib/wcs-1.5.4.jar!/applicationContext.xml]
2557 [main] INFO
ps/geoserver/WEB-INF/lib/wms-1.5.4.jar!/applicationContext.xml]
2831 [main] INFO
ps/geoserver/WEB-INF/lib/validation-1.5.4.jar!/applicationContext.xml]
2868 [main] INFO
ps/geoserver/WEB-INF/lib/data-1.5.4.jar!/applicationContext.xml]
2906 [main] INFO
bean definitions from URL [file:/home/geoserver/geoserver/webapps/g
eoserver/WEB-INF/classes/applicationContext.xml]
3097 [main] INFO
ps/geoserver/WEB-INF/lib/wfs-1.5.4.jar!/applicationContext.xml]
3158 [main] INFO
ps/geoserver/WEB-INF/lib/main-1.5.4.jar!/applicationContext.xml]
3302 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContex t - Bean
factory for application context [Root WebApplicationContext]: org.sprin
gframework.beans.factory.support.DefaultListableBeanFactory defining beans
[wcs,
wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGet
Capabilities,wcsDescribeCoverage,wcsGetCoverage,wms,wmsConfig,wmsRegisterar,wmsC
onfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilit
iesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap
,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,J
aiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMa
pProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFact
ory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapPro
ducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,validation,va
lidationConfig,validationRegisterar,validationConfigRegisterar,catalog,serviceFi
nder,applicationState,applicationStateRegisterar,wfs,wfsConfig,wfsRegisterar,wfs
ConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFea
tureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,confi
g,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,glo
balConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy
,bufferServiceStrategy,partialBufferServiceStrategy2]; root of BeanFactory
hiera rchy
3333 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContex t - 72 beans
defined in application context [Root WebApplicationContext]
3364 [main] INFO org.springframework.core.CollectionFactory - JDK 1.4+
collectio ns available
3399 [main] INFO org.springframework.core.CollectionFactory - Commons
Collection s 3.x available
3413 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContex t - Unable
to locate MessageSource with name 'messageSource': using default [org
.springframework.context.support.DelegatingMessageSource@anonymised.com]
3433 [main] INFO
to locate ApplicationEventMulticaster with name 'applicationEventMult
icaster': using default
[org.springframework.context.event.SimpleApplicationEven
tMulticaster@anonymised.com]
3470 [main] INFO
org.springframework.ui.context.support.UiApplicationContextUtil s - Unable
to locate ThemeSource with name 'themeSource': using default [org.spr
ingframework.ui.context.support.ResourceBundleThemeSource@anonymised.com]
3501 [main] INFO
org.springframework.beans.factory.support.DefaultListableBeanFa ctory -
Pre-instantiating singletons in factory [org.springframework.beans.facto
[wcs,wcsConfig,wcsRegistera
r,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescri
beCoverage,wcsGetCoverage,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbs
tractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeF
eatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPu
tStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactor
y,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffM
apProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFact
ory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayer
sMapProducerFactory,GeoRSSMapProducerFactory,validation,validationConfig,validat
ionRegisterar,validationConfigRegisterar,catalog,serviceFinder,applicationState,
applicationStateRegisterar,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAb
stractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature
,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,config,geoServer,globalConf
ig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,ge
oServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy
,partialBufferServiceStrategy2]; root of BeanFactory hierarchy]
- GEOSERVER_DATA_DIR: /home/geoserver/geoserver/data_dir
20.12.2007 09:07:29 java.util.prefs.FileSystemPreferences$7 run
WARNUNG: Prefs file removed in background
/root/.java/.userPrefs/org/vfny/geoser ver/global/prefs.xml
0 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - logging level is
CONF IG
27 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - maxFeatures is
10000 00
28 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - numDecimals
returnin g is 8
29 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - charSet is UTF-8
46 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - reading
srsXmlStyle: [srsXmlStyle: null]
4892 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat ion file: /home/geoserver/geoserver/data_dir/catalog.xml
4906 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:it.geosolutions="http://www.geo-solutions.it",
isDefault=false
4907 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:cite="http://www.opengeospatial.net/cite", isDefault=false
4908 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:tiger="http://www.census.gov", isDefault=false
4910 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:sde="http://geoserver.sf.net", isDefault=false
4911 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:topp="http://www.openplans.org/topp", isDefault=true
namespace xm lns:sf="http://www.openplans.org/spearfish", isDefault=false
4914 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xm lns:nurc="http://www.nurc.nato.int", isDefault=false
4932 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore t asmania_cities
4933 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore s fRoads
5342 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore D S_tiger_roads
5343 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore t asmania_roads
datastore v map_shp
5346 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore t asmania_water_bodies
5347 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore s fArchsites
datastore s fBugsites
5350 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore D S_poi
5351 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore s tates_shapefile
datastore D S_giant_polygon
5354 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore D S_poly_landmarks
5355 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore s fStreams
datastore s fRestricted
5358 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore t asmania_state_boundaries
5360 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore t est_vmap
5364 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
capit als
simpl e_roads
5365 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
cite_ lakes
5367 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
green
5368 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
giant _polygon
simpl e_streams
5370 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
line
5371 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
polyg on
poi
5374 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
raste r
point
5375 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
tiger _roads
5377 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
burg
5378 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
dem
poly_ landmarks
5381 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
popul ation
5384 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/DS_poi_poi/info.xml
5396 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType poi
5398 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5399 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/tasmania_cities/info.x ml
5405 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_cities
5406 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5407 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/sfRoads_roads/info.xml
5417 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType roads
5418 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5419 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/sfRestricted_restricte
d/info.xml
5428 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType restricted
5429 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5430 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/tasmania_roads/info.xm l
5436 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_roads
5436 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5437 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/tasmania_state_boundar
ies/info.xml
5443 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_state_boundaries
5444 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5445 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/DS_poly_landmarks_poly
_landmarks/info.xml
5453 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType poly_landmarks
5454 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5455 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/sfBugsites_bugsites/in
fo.xml
5463 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType bugsites
5464 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5465 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/states/info.xml
5472 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType states
5473 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5474 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/tasmania_water_bodies/
info.xml
5480 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_water_bodies
5481 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5482 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/DS_tiger_roads_tiger_r
oads/info.xml
5485 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tiger_roads
5486 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5487 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/DS_giant_polygon_giant
_polygon/info.xml
5490 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType giant_polygon
5491 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5492 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/sfArchsites_archsites/
info.xml
5497 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType archsites
5498 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5499 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/sfStreams_streams/info .xml
5504 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType streams
5505 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5506 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/test_vmap_MISINDP_IND_
___POINT/info.xml
5527 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType MISINDP_IND____POINT
5528 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
5530 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
/home/geoserver/geoserver/data_dir/featureTypes/test_vmap_LIBREF_LIBRE
F____LINE/info.xml
5533 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType LIBREF_LIBREF____LINE
5534 [KONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
20.12.2007 09:07:34 java.util.prefs.FileSystemPreferences$7 run
/root/.java/.userPrefs/org/geotools/re ferencing/wkt/prefs.xml
10105 [SCHWERWIEGEND] org.vfny.geoserver.global.Data - FeatureTypeInfo
test_vmap :::MISINDP_IND____POINT ignored - as DataStore test_vmap is
unavailable:org.geot ools.data.SchemaNotFoundException: Feature type could
not be found for MISINDP_I ND____POINT
10372 [WARNUNG] org.geotools.data.oracle.OracleDataStore - Could not map
SRID 0 to CRS:org.geotools.data.DataSourceException: No geometry column row
for srid in table: LIBREF_LIBREF____LINE, geometry column ORA_GEOMETRY, be
sure column is d efined in USER_SDO_GEOM_METADATA
10585 [SCHWERWIEGEND] org.vfny.geoserver.global.Data - FeatureTypeInfo
test_vmap :::LIBREF_LIBREF____LINE ignored - as DataStore test_vmap is
unavailable:org.geo tools.data.DataSourceException: No geometry column row
for srid in table: LIBREF _LIBREF____LINE, geometry column ORA_GEOMETRY, be
sure column is defined in USER _SDO_GEOM_METADATA
15090 [main] INFO org.springframework.web.context.ContextLoader - Using
context class
[org.springframework.web.context.support.XmlWebApplicationContext] for roo t
15091 [main] INFO org.springframework.web.context.ContextLoader - Root
WebApplic ationContext: initialization completed in 12778 ms
16184 [main] INFO org.apache.struts.tiles.TilesPlugin - Tiles definition
factory loaded for module ''.
16188 [main] INFO org.apache.struts.validator.ValidatorPlugIn - Loading
validati on rules file from '/WEB-INF/validator-rules.xml'
16195 [main] INFO org.apache.struts.validator.ValidatorPlugIn - Loading
validati on rules file from '/WEB-INF/validation.xml'
16290 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
ContextLo aderPlugIn for Struts ActionServlet 'action, module '':
16291 [main] INFO /geoserver - Initializing WebApplicationContext for Struts
Act ionServlet 'action', module ''
16297 [main] INFO
bean definitions from ServletContext resource [/WEB-INF/action-ser vlet.xml]
16313 [main] INFO
org.springframework.web.context.support.XmlWebApplicationConte xt - Bean
factory for application context [WebApplicationContext for namespace '
action-servlet']:
org.springframework.beans.factory.support.DefaultListableBeanF actory
defining beans [/admin/loginSubmit]; parent: org.springframework.beans.fa
erar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDes
cribeCoverage,wcsGetCoverage,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wms
AbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescri
beFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wm
sPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFac
tory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,Ti
ffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerF
actory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLa
yersMapProducerFactory,GeoRSSMapProducerFactory,validation,validationConfig,vali
dationRegisterar,validationConfigRegisterar,catalog,serviceFinder,applicationSta
te,applicationStateRegisterar,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wf
sAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeat
ure,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,config,geoServer,globalC
onfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar
,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrat
egy,partialBufferServiceStrategy2]; root of BeanFactory hierarchy
16314 [main] INFO
org.springframework.web.context.support.XmlWebApplicationConte xt - 1 beans
defined in application context [WebApplicationContext for namespace
'action-servlet']
16316 [main] INFO
org.springframework.web.context.support.XmlWebApplicationConte xt - Unable
g.springframework.context.support.DelegatingMessageSource@anonymised.com]
16317 [main] INFO
ticaster': using default
ntMulticaster@anonymised.com]
16317 [main] INFO
org.springframework.ui.context.support.UiApplicationContextUti ls - Unable
ringframework.ui.context.support.DelegatingThemeSource@anonymised.com]
16317 [main] INFO
org.springframework.beans.factory.support.DefaultListableBeanF actory -
ory.support.DefaultListableBeanFactory defining beans [/admin/loginSubmit];
pare nt:
org.springframework.beans.factory.support.DefaultListableBeanFactory definin
g beans
[wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsS
ervice,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wms,wmsConfig,wmsRe
gisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wm
sGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGrap
hic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProd
ucerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFact
ory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMa
pProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFacto
ry,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,
validation,validationConfig,validationRegisterar,validationConfigRegisterar,cata
log,serviceFinder,applicationState,applicationStateRegisterar,wfs,wfsConfig,wfsR
egisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,w
fsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTran
saction,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigR
egisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileSe
rviceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2]; root of
Bean Factory hierarchy]
16328 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn - Using
con text class
'org.springframework.web.context.support.XmlWebApplicationContext' fo r
servlet 'action'
ContextLo aderPlugIn for Struts ActionServlet 'action', module '':
initialization complete d in 38 ms
16352 [main] INFO org.mortbay.log - Started SelectChannelConnector @
0.0.0.0:808 0
18502 [btpool0-5] INFO org.apache.struts.tiles.TilesRequestProcessor - Tiles
def inition factory found for request processor ''.
data/example.extension
the failsures named [Schwerwiegend], are from an other project.
-gabriel
View this message in context: http://www.nabble.com/How-to-import-VMap0-with-VPF-Extension-to-GeoServer--tp14418942p14432647.html
