[Geoserver-users] How to improve documentation of REST?
REST is probably the most common topic on this list. This search finds 5208 mails:
http://sourceforge.net/p/geoserver/mailman/search/?q=REST
I interpret that REST interests users but it is difficult to use and documents that we have do not cover enough use cases. We have documentation in http://docs.geoserver.org/stable/en/user/rest/index.html and
http://docs.geoserver.org/stable/en/user/rest/api/index.html#rest-api and usage examples in
http://docs.geoserver.org/stable/en/user/rest/examples/index.html#rest-examples
Documentation is not bad but obviously it should be made better. Any suggestions about how to improve it? I believe that is should be something community driven or community assisted because developers are busy with other things and getting funding for improving documentation is just a dream.
-Jukka Rahkonen-
I've had some success with documenting the "representation" classes with Javadoc and then using a tool that understands Spring MVC annotations to generate HTML documentation from the code, that way the REST API docs stay in sync with the code. The onus though is on the developer working on that portion of the REST API to ensure that good documentation is written up in the Javadoc.
I have done this successfully with RESTdoclet.
This way you get full coverage of all the REST API resources available; what operations are allowed for those resources, the query parameters, and request body parameters all generated from the code (Spring MVC annotations) and Javadoc.
There are several other tools that do this. Then leave it up to the community to add REST API usage examples as they discover more use cases for how they use it.
My two cents,
--Steve
-----Original Message-----
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com]
Sent: Wednesday, September 10, 2014 6:41 AM
To: 'Geoserver-users@lists.sourceforge.net'
Subject: [Geoserver-users] How to improve documentation of REST?
I interpret that REST interests users but it is difficult to use and documents that we have do not cover enough use cases. We have documentation in http://docs.geoserver.org/stable/en/user/rest/index.html and http://docs.geoserver.org/stable/en/user/rest/api/index.html#rest-api and usage examples in http://docs.geoserver.org/stable/en/user/rest/examples/index.html#rest-examples
-Jukka Rahkonen-
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Steve,
Maybe I missed something.
Do you mean the doc generated for the REST API here ? http://docs.geoserver.org/2.5.x/en/user/rest/api/index.html
Because I’m still on my imagemosaic thing, and something bothers me : in the REST API, I saw nothing about external.imagemosaic service. Shouldn’t it be exposed in the coveragestores section, as it is in the datastore section ? Datastore section documents a [file|url|external][.<extension>] service while coveragestores only documents file[.<extension>] service
But maybe it’s just some inline doc missing in the code ?
Jean
My two cents,
--Steve
From: Rahkonen Jukka (Tike) [[mailto:jukka.rahkonen@anonymised.com](mailto:jukka.rahkonen@anonymised.com)]
To: '[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comists.sourceforge.net)'
[http://sourceforge.net/p/geoserver/mailman/search/?q=REST](http://sourceforge.net/p/geoserver/mailman/search/?q=REST)
I interpret that REST interests users but it is difficult to use and documents that we have do not cover enough use cases. We have documentation in  [http://docs.geoserver.org/stable/en/user/rest/index.html](http://docs.geoserver.org/stable/en/user/rest/index.html) and [http://docs.geoserver.org/stable/en/user/rest/api/index.html#rest-api](http://docs.geoserver.org/stable/en/user/rest/api/index.html#rest-api) and usage examples in [http://docs.geoserver.org/stable/en/user/rest/examples/index.html#rest-examples](http://docs.geoserver.org/stable/en/user/rest/examples/index.html#rest-examples)
-Jukka Rahkonen-
Want excitement?
[http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk](http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Want excitement?
Jean Pommier – pi-Geosolutions
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
I’m guessing that the use of “external” is just not documented for coveragestores because it does appear to work for me.
–Steve
From: Jean Pommier [mailto:jean.pommier@anonymised.com]
Sent: Friday, September 12, 2014 3:05 AM
Subject: Re: [Geoserver-users] How to improve documentation of REST?
Hi Steve,
Because I’m still on my imagemosaic thing, and something bothers me : in the REST API, I saw nothing about external.imagemosaic service. Shouldn’t it be exposed in the coveragestores section, as it is in the datastore section ? Datastore section documents a [file|url|external][.] service while coveragestores only documents file[.] service
Jean
My two cents,
--Steve
From: Rahkonen Jukka (Tike) [[mailto:jukka.rahkonen@anonymised.com](mailto:jukka.rahkonen@anonymised.com.)]
To: '[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)'
-Jukka Rahkonen-
Want excitement?
Want excitement?
