Dear Friends,
I got a satellite map of a small district in india as TIFF format , i published the map using image mosaic raster form. but the map showing in layer preview have less clarity and some where pink color comes up, map rendering speed is also slow is there any way to solve this issue
Check if you have overviews and internal tiling on the image. These significantly help with rendering speed. Also, if you don’t expect the image to change very often, you can utilize the built-in GeoWebcache GWC to return pre-rendered tiles.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Dear Friends,
