[Geoserver-users] How to install Geoserver Authentication with LDAP?
I was add acme-ldap.jar into WEB-INF/lib directory. Restart server and go to Authentication Provider menu.
But i cant use it. I try http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html but get error:
javax.naming.CommunicationException: localhost:10389
[Root exception is java.net.ConnectException: Connection refused: connect]
I try to use ldap.xml for http://www.mulesoft.org/documentation-3.2/display/32X/Enabling+Authentication+Through+LDAP#EnablingAuthenticationThroughLDAP-setldap but not help i just get same result.
Whats wrong how to use ldap in Geoserver?
You’re supposed to run acme-ldap.jar as a separate java application. It’s not a plugin for GeoServer, it’s a dummy LDAP server with the example directory used for the tutorial.
Try New Relic Now & We’ll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_may
Geoserver-users mailing list
Kevin Smith
Junior Software Developer, OpenGeo
<ksmith@anonymised.com>
