[Geoserver-users] how to install/upgrade a new geoserver release while retaining the old configuration?
Hi list,
i would like to know how could i upgrade an existing geoserver installation while retaining the old configuration? I get the whole installation if there is a new release. Is there a workaround which jars to update for every new release? Or do i have to save the configuration files of all datastores, user made sld’s and featureTypes-info.xml’s?
Best
Albrecht
Hi Albrecht,
Just take told data directory (<installation>/data_dir) and move it somewhere. Then set set the GEOSERVER_DATA_DIR environment variable to the new location. When you start up the new version it should continue to use your old configuration directory.
-Justin
Albrecht.Weiser@anonymised.com wrote:
Hi list,
i would like to know how could i upgrade an existing geoserver installation while retaining the old configuration? I get the whole installation if there is a new release. Is there a workaround which jars to update for every new release? Or do i have to save the configuration files of all datastores, user made sld's and featureTypes-info.xml's?
Best
Albrecht
!DSPAM:4007,4861046447695409313003!
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
The recommended way to do this is to use the GEOSERVER_DATA_DIR parameter in web.xml to specify some directory outside of GeoServer to use as the data dir.
More info at http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
Hope this helps,
-David Winslow
Hi list,
Best
Albrecht
!DSPAM:4040,4861046447711637810514!
