[Geoserver-users] How to know in a coordinate (x, y) is into a ascii grid file
Hello,
I'm a beginner in using asc grid and geotools library. I'm developing some
processes in java and I would understand the way to know if a generic
coordinate (x,y) is inside the asc file using geotools libraries.
Thanks in advance for any help you will give me.
Sandro
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-know-in-a-coordinate-x-y-is-into-a-ascii-grid-file-tp5138303.html
Hi Sandro,
it think you can have a better answer in the GeoTools mailing list.
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
Anyway, I guess you can get the envelope of the grid and check the
coordinates on it.
  File file = new File("/home/xxx/grid.asc");
  AbstractGridFormat format = GridFormatFinder.findFormat(file);
  reader = format.getReader(file);
  GridCoverage2D coverage = reader.read(null);
  Envelope2D envelope = coverage.getEnvelope2D(); // the envelope
  DirectPosition2D point_to_check = new DirectPosition2D ( x , y ); //
your coordinates
  boolean is_inside = envelope.contains(point_to_check); // check if
point is inside the envelope
Regards
Lorenzo Pini
Software Engineer
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Via Poggio alle Viti 1187
On Fri, May 2, 2014 at 4:56 PM, spresta73 <sandro.presta@anonymised.com> wrote:
Hello,
Sandro
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
