Hey,
I want to display layer in the map from a Json API
How to add this API in geoserver ?
Do you want it in GeoServer? Or on a web page …
If you just want to combine your data with a geoserver map you can do so using a client library such as OpenLayers.
If you wish create a new data source, teaching geoserver how to access your JSON API - that is fine also. The library used for data access is GeoTools; and there is a tutorial on how to write a data store.
Jody
Jody Garnett
Thanks , I mean in web page
Jody
On Mon, Oct 25, 2021 at 1:15 PM kaoutar hraka <hrk.kawtar@anonymised.com> wrote:
Hey,
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
Jody Garnett
Check out Open layers or Leaflet. Mike Miller has some great tutorials on getting started with Leaflet.
On Thu., Oct. 28, 2021, 12:57 a.m. kaoutar hraka, <hrk.kawtar@anonymised.com> wrote:
Le jeu. 28 oct. 2021 06:21, Jody Garnett <jody.garnett@anonymised.com4…> a écrit :
Jody
Hey,
Geoserver-users@anonymised.comnet
Jody Garnett
