[Geoserver-users] How to make graphics not follow line in line symboliser?
I have a simple line symbolizer with a graphic stroke on top. By default it seems like the symbol will rotate to follow the direction of the line.
shape://oarrow
#000000
2
24
How can I force the symbol not to rotate?
I have tried to include the TextSymboliser VendorOption followLine, but the SLD wont validate with it.
There is a question on GIS.SE with the same question: http://gis.stackexchange.com/questions/58776/sld-disable-follow-line
Regards, Casper
On Mon, Jul 21, 2014 at 10:18 AM, Casper Børgesen (CABO) <CABO@anonymised.com...>
<LineSymbolizer>
  <Stroke>
    <GraphicStroke>
      <Graphic>
        <Mark>
          <WellKnownName>shape://oarrow</WellKnownName>
          <Stroke>
            <CssParameter name="stroke">#000000</CssParameter>
            <CssParameter name="stroke-width">2</CssParameter>
          </Stroke>
        </Mark>
        <Size>24</Size>
      </Graphic>
    </GraphicStroke>
  </Stroke>
</LineSymbolizer>
I have tried to include the TextSymboliser VendorOption *followLine*, but
There is no way to do that, the SLD specification says:
"A repeated linear graphic is plotted linearly and has its graphic
symbol bent around the curves of the line string"
In order to do what you want we'd need to add a new vendor option to force
the out of spec behavior,
and some code would have to be written to implement it.
Feel free to:
* open a ticket for a new feature request at
http://jira.codehaus.org/browse/GEOT
* implement it and make a pull request on github, or
* look into commercial support options to have someone implement it for you
http://docs.geotools.org/stable/userguide/welcome/support.html#commercial-support
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea.
Thanks for your quick clarification. I have created a feature request: http://jira.codehaus.org/browse/GEOS-6585
Regards, Casper
On Mon, Jul 21, 2014 at 10:18 AM, Casper Børgesen (CABO) <CABO@…4891…> wrote:
shape://oarrow
#000000
2
24
In order to do what you want we’d need to add a new vendor option to force the out of spec behavior,
Feel free to:
  • open a ticket for a new feature request at http://jira.codehaus.org/browse/GEOT
  • implement it and make a pull request on github, or
  • look into commercial support options to have someone implement it for you
(http://docs.geotools.org/stable/userguide/welcome/support.html#commercial-support)
Ing. Andrea Aime
@geowolf
Technical Lead
