[Geoserver-users] How to make the GeoTiff background image to transparent in SLD?
Hi All,
I’m publishing a GeoTiff image using geoserver.
The background value zeor is appearing black in the output web map.
Is there a way to make the background color to transparent?
Thank you in advance for any help
Best regards
Have a nice day!
Mr. Khun San Aung
Dear Khun San Aung,
which type of GeoTIFF are you publishing? (RGB/Gray/paletted?)
Which GeoServer version are you using?
In general, you could set the InputTransparentColor=000000 in layer’s configuration (In Data tab. scroll down after the BoundingBoxes, in the Coverage Parameters section).
Alternatively, if you are using a color map SLD to color your images, you can set an entry with opacity=0.
Please, let us know if that works for you.
Best Regards,
Daniele
On Fri, Jul 24, 2015 at 2:15 PM, KhunSanAung <khunsanaung.gis@anonymised.com> wrote:
Hi All,
Best regards
Have a nice day!
Mr. Khun San Aung
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
GeoServer 2.7
RGB color.
using the default SLD that come with Geoserver.
Where do I have to change?
Many thanks for your reply
Best regards
On Fri, Jul 24, 2015 at 7:41 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Dear Khun San Aung,
Best Regards,
Daniele
Hi All,
Best regards
Have a nice day!
Mr. Khun San Aung
Have a nice day!
Mr. Khun San Aung
On Fri, Jul 24, 2015 at 3:24 PM, KhunSanAung <khunsanaung.gis@anonymised.com>
wrote:
GeoServer 2.7
RGB color.
From the Left area of the GUI, select *Layers* link from "Data" list.
Then search for your specific layer from the list of configured layers and
click on that one.
Finally, scroll down the configuration section till Coverage
Parameters subsection
and set InputTransparentColor to 000000.
Hope this helps.
Daniele
Best regards
Dear Khun San Aung,
In general, you could set the InputTransparentColor=000000 in layer's
Best Regards,
Daniele
wrote:
Hi All,
I'm publishing a GeoTiff image using geoserver.
Best regards
Have a nice day!
*Mr. Khun San Aung*
* <http://geoportal.icimod.org/&gt;\*
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be confidential
or proprietary in nature or covered by the provisions of privacy act
Have a nice day!
*Mr. Khun San Aung*
Many thanks, it works
On Fri, Jul 24, 2015 at 8:14 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
On Fri, Jul 24, 2015 at 3:24 PM, KhunSanAung <khunsanaung.gis@anonymised.com> wrote:
GeoServer 2.7
RGB color.
From the Left area of the GUI, select Layers link from “Data” list.
Then search for your specific layer from the list of configured layers and click on that one.
Finally, scroll down the configuration section till Coverage Parameters subsection and set InputTransparentColor to 000000.
Hope this helps.
Daniele
Best regards
Dear Khun San Aung,
Best Regards,
Daniele
Have a nice day!
Mr. Khun San Aung
Hi All,
Best regards
Have a nice day!
Mr. Khun San Aung
Have a nice day!
Mr. Khun San Aung
