I have Geoserver set up in 4 environments, each one deployed into a Tomcat container on 4 separate servers. I have used JNDI in Tomcat to create the database connections as this does not need to be changed when Geoserver is updated.
Having done this then, each Geoserver instance has the same configuration.
Graham Humphries | Acting Manager Spatial Capability
Department of State Growth
4 Salamanca Place, Hobart TAS 7000 | GPO Box 536, Hobart TAS 7001
P: (03) 6166 3155
www.stategrowth.tas.gov.au
Courage to make a difference through
TEAMWORK | INTEGRITY | RESPECT | EXCELLENCE
In recognition of the deep history and culture of this island, I acknowledge and pay my respects to all Tasmanian Aboriginal people; the past, and present custodians of the Land.
From: christophe.garault.ext@anonymised.com553… christophe.garault.ext@anonymised.com
Sent: Tuesday, February 20, 2024 2:27 AM
Subject: [Geoserver-users] How to parameterize password of a datastore ?
Is there a way to parameterize the password field of a datastore as with others fields as shown in the doc (https://docs.geoserver.org/latest/en/user/datadirectory/configtemplate.html)
We have several environments which doesn’t necessarily have the same password.
I tried to set something like this without any success in the properties file:
database.passwd=crypt1:xxxxxxx
Thanks in advance
Christophe GARAULT
____________________________________________________________________________________________________________
Ce message et ses pieces jointes peuvent contenir des informations confidentielles ou privilegiees et ne doivent donc
pas etre diffuses, exploites ou copies sans autorisation. Si vous avez recu ce message par erreur, veuillez le signaler
a l'expediteur et le detruire ainsi que les pieces jointes. Les messages electroniques etant susceptibles d'alteration,
Orange decline toute responsabilite si ce message a ete altere, deforme ou falsifie. Merci.
This message and its attachments may contain confidential or privileged information that may be protected by law;
they should not be distributed, used or copied without authorisation.
If you have received this email in error, please notify the sender and delete this message and its attachments.
As emails may be altered, Orange is not liable for messages that have been modified, changed or falsified.
Thank you.
