Is there any way to pass user parameters through GeoServer that can be used
in a PostGIS query? I am trying to figure out how to retrieve summary data
(calculated by PostGIS) based on some user supplied parameters.
As a concrete example, I'll refer to some PostGIS datasets described on the
following page:
http://geoserver.org/display/GEOSDOC/Tropical+Storm+Tracking+with+PostGIS-GeoServer-GoogleEarth
Consider two datasets: storm tracks (line geometry) and US state boundaries
(polygon geometry). Is there a way to construct a request that returns the
number of storm tracks that intersect state boundaries within a user
specified time?
Within PostGIS, I can construct a prepared statement (see below) that
creates the summary data using two parameters (i.e. start time and end
time). Is there any way to pass these parameters from GeoServer, and
retrieve back the results of the prepared statement? Or is there a better
way to go about doing this?
- Tyler
-- DEALLOCATE p_storm_count;
PREPARE p_storm_count (timestamp, timestamp) AS
SELECT
s.state_name,
count(t.storm_num) as storm_count
FROM
v_storm_track as t,
states as s
WHERE
storm_start BETWEEN $1 and $2 AND
ST_Intersects(t.the_route, s.the_geom)
GROUP BY
s.state_name
ORDER BY
s.state_name;
EXECUTE p_storm_count('1/1/1995', '10/1/1998');
EXECUTE p_storm_count('1/1/1995', '10/1/2003');
EXECUTE p_storm_count('1/1/2000', '10/1/2005');
View this message in context: http://www.nabble.com/how-to-pass-user-parameters-to-PostGIS-queries--tp16967374p16967374.html
On Tue, Apr 29, 2008 at 12:43 PM, Tyler Erickson <tyler.erickson@anonymised.com> wrote:
With a WFS request, one can use the OGC filters to specify criteria.
There are examples if you follow the "Demo/Sample Requests" link on
your Geoserver installation.
With a WMS request, I am not sure--although I use the filter parameter
that Andrea implemented:
http://geoserver.org/display/GEOSDOC/WMS+vendor+parameters
Is this still a valid way to use filters with WMS requests in the 1.6
geoserver releases?
Alex
Alex,
To my best understanding, the OGC and CQL filters can only be used to filter records that are returned from a datastore, and cannot be used to supply parameters to SQL aggregate functions (such as COUNT or SUM) within a PostGIS datastore. So while they could be used to return all records between a given start_time and end_time, it is not clear to me how they could be used to return a count of records between a given start_time and end_time.
Alexander Petkov wrote:
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute
3600 Green Court, Suite 100
Ann Arbor, MI 48105
[tyler.erickson@anonymised.com](mailto:tyler.erickson@anonymised.com)
[www.mtri.org](http://www.mtri.org)
[www.michiganview.org](http://www.michiganview.org)
On Tue, Apr 29, 2008 at 1:25 PM, Tyler Erickson <tyler.erickson@anonymised.com> wrote:
Alex,
end_time.
- Tyler
Ah, I see... In this case, if your goal is to get the results
displayed on a web page, the first thing that comes to mind is to make
an Ajax call.
One potential client app could be a web page, in which case it seems like the records could be aggregated by the client (using ajax). But I would also like to be able to use Google Earth as a client and be able to specify the start_time and end_time in the URL that is sent to GeoServer from a Google Earth network link.
I’m kind of skeptical about using the client application to aggregate the data, given the size of the datasets we work with (> million records) will likely overwhelm the web browser or Google Earth. I am hoping there is a way to let the database perform the aggregation and reduce the dataset to a more reasonable size, since that is what it is good at doing…
Research Scientist
Ann Arbor, MI 48105
hi,
what about passing parameters via WMS to dynamically construct a SLD?
you pass timestamps that are used by postGIS, execute the query, get the
results (count) and insert them in the newly created SLD.
This SLD can then be called from the <Url> tag in the KML (which can also
refer to start_time and end_time in the URL).
Maybe this post helps you
(http://www.nabble.com/Changing-dynamically-SLD-using-php-td12781786.html#a12781786)
hope it helps,
Pere Roca
visit EDIT project!
http://edit.csic.es/edit_geo/prototype/edit_project.html
used in a PostGIS query? I am trying to figure out how to retrieve
summary data (calculated by PostGIS) based on some user supplied
parameters.
the following page:
boundaries (polygon geometry). Is there a way to construct a request that
returns the number of storm tracks that intersect state boundaries within
a user specified time?
- Tyler
SELECT
s.state_name,
FROM
v_storm_track as t,
states as s
WHERE
GROUP BY
s.state_name
ORDER BY
s.state_name;
View this message in context: http://www.nabble.com/how-to-pass-user-parameters-to-PostGIS-queries--tp16967374p16978504.html
Pere,
That sounds like a promising (and creative) way to incorporate the
user-supplied parameters.
Would you be willing to share your states_filter.php script so that I could
use it as a starting point?
- Tyler
pere roca wrote:
hi,
hope it helps,
Pere Roca
visit EDIT project!
View this message in context: http://www.nabble.com/how-to-pass-user-parameters-to-PostGIS-queries--tp16967374p16982338.html
Tyler,
below there is a very simple php that constructs a SLD getting the passed
parameters
(http://edit.csic.es/geoserver/wms?bbox=-127.61950064999999,23.7351786,-64.08177035,50.592523400000005&format=application/openlayers&request=GetMap&width=800&height=317&srs=EPSG:4326&sld=http://edit.csic.es/gmap/states_filter.php?state=Florida)
; states parameters can be changed.
For your purpose you need more complex php stuff that can slow the GetMap
response. Maybe you find some interesting code in the SVN of the project
I'm working for: http://dev.e-taxonomy.eu/trac/browser/trunk/geo/mapviewer/
(check lines 127 and more of data_upload.php to retrieve and construct a SLD
using php and XSLT); you can see the webapplication in
http://edit.csic.es/edit_geo/prototype/edit.html
cheers,
(make me know if it fits for you, I also would be interested to do
something similar on the future)
Pere Roca
states_filter.php
<?php
header("Content-type: text/xml");
echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<!-- a named layer is the basic building block of an sld document -->
<NamedLayer>
<Name>topp:states</Name>
<!-- with in a layer you have Named Styles -->
<UserStyle>
<!-- again they have names, titles and abstracts -->
<Name>population</Name>
<Title>Population in the United States</Title>
<Abstract>A sample filter that filters the United States into three
categories of population, drawn in different colors</Abstract>
<FeatureTypeStyle>
<Rule>
<!-- like a linesymbolizer but with a fill too -->
<ogc:Filter xmlns:gml="http://www.opengis.net/gml">
<ogc:And>
<ogc:PropertyIsLike wildCard="*" singleChar="?" escape="\">
<ogc:PropertyName>STATE_NAME</ogc:PropertyName>
<ogc:Literal><?php echo($_GET['state']);
?></ogc:Literal>
</ogc:PropertyIsLike>
</ogc:And>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<!-- CssParameters allowed are fill (the color) and
fill-opacity -->
<CssParameter name="fill">#FF4D8F</CssParameter>
</Fill>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Pere,
could use it as a starting point?
- Tyler
pere roca wrote:
hi,
hope it helps,
Pere Roca
visit EDIT project!
View this message in context: http://www.nabble.com/how-to-pass-user-parameters-to-PostGIS-queries--tp16967374p16983047.html
