[Geoserver-users] How to print legend image?
Hi.
I trying to print legend image using print module. In my config.yaml i have:
  • !legends
    backgroundColor: #FFFFFF
    horizontalAlignment: left
    inline: false
    defaultScale: 0.5
    iconMaxWidth: 0
    iconMaxHeight: 0
    iconPadding: 3 0 0 0
    textMaxWidth: 300
    textMaxHeight: 0
    textPadding: 0 10 0 10
    columnMaxWidth: 0
    classIndentation: 20
    layerSpaceBefore: 10
    layerSpace: 25
    classSpace: 10
    layerFont: Arial
    layerFontSize: 14
    classFont: Arial
    classFontSize: 12
    fontEncoding: Cp1252
But when i tried print a style with multiple rules image was too smal to read it. Like as in atached example. What can i do with this problem?
mapfish-print-geoserver.pdf (54.1 KB)
Hi Макс,
depending on the mapfish print-lib version you are using you need to use a different property in you !legends block:
maxIconHeight: 0 for print-lib 1.2
iconMaxHeight:0 for print-lib 2.x
I see you are using the second version, but you are probably still using print-lib version 1.2 (this is the default on Geoserver 2.5.x and previous versions, the 2.1 version will instead be used on 2.6.x).
Mauro
Mauro
2014-07-22 17:48 GMT+02:00 Макс Кливер <dh0m0ch@…84…>:
Hi.
  • !legends
    inline: false
    defaultScale: 0.5
    iconMaxWidth: 0
    iconMaxHeight: 0
    textMaxWidth: 300
    textMaxHeight: 0
    columnMaxWidth: 0
    layerSpace: 25
    classSpace: 10
    layerFont: Arial
    layerFontSize: 14
    classFont: Arial
    classFontSize: 12
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
Hi Mauro,
I use Geoserver 2.3 and 2.5, so maxIconHeight: 0 for print-lib 1.2 help for me.
Thanks you!
Max.
On Tue, Jul 22, 2014 at 10:09 PM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com> wrote:
Hi Макс,
Mauro
Mauro
2014-07-22 17:48 GMT+02:00 Макс Кливер <dh0m0ch@anonymised.com>:
Hi.
  • !legends
    inline: false
    defaultScale: 0.5
    iconMaxWidth: 0
    iconMaxHeight: 0
    textMaxWidth: 300
    textMaxHeight: 0
    columnMaxWidth: 0
    layerSpace: 25
    classSpace: 10
    layerFont: Arial
    layerFontSize: 14
    classFont: Arial
    classFontSize: 12
