!columns #This line determines if the legend is shown in the template.
condition: legends
absoluteX: 56
absoluteY: 764
width: 280
config:
borderWidth: 1
borderColor: black
cells:
And i exepect that it print legend in two columns but it do not do it. I take this gonfig here http://cageyjames.webfactional.com/?cat=1276 and on example i see that this legend configuration generate legend in two columns.
multi columns legends should be supported by mapfish-print 2.0 and 2.1.
Unfortunately Geoserver 2.5 is still based on mapfish-print 1.2, but the upcoming 2.6 has been upgraded to 2.1, so you should be able to get what you are asking for.
Note that the yaml you are referring to is compatible with our internal experimental version, but some functionality has not been ported to the official release yet, so probably you will need to change a bit your configuration to make it work.
You can find the official configuration documentation for 2.6 print plugin here: http://docs.geoserver.org/latest/en/user/extensions/printing/configuration.html
condition: legends
absoluteX: 56
absoluteY: 764
width: 280
config:
borderWidth: 1
borderColor: black
cells:
