[Geoserver-users] How to set GWC to make connection through proxy?
I would like to use GWC for caching an external WMS service which must be connected through our company proxy. I have tried to edit the catalina.properties file in Tomcat 6.0_36 by addind these lines to the end of the file.
http.proxyHost=ourProxyURL
http.proxyPort=ourProxyPort
However, GWC does not make connection. GeoWebcache version is 1.4-Snapshot from a month ago.
Is editing catalina.properties principally the right thing to do?
Geowebcache.xml has configuration option for http username and password as
<httpUsername> and <httpPassword>. It would be handy if proxy settings could also be configured in the same file.
I could make the system work by installing Mapserver WMS as a proxy between the remote WMS and GWC, but it is one component too much and it also hides error messages coming from the primary WMS server. This leads to storing white tiles into the GWC cache directory and they are hard to find and reseed.
-Jukka Rahkonen-
