[Geoserver-users] How to set InputTransparentColor for MrSid layers?
I’ve just started using GeoServer/GeoWebCache to serve map imagery to web clients which use the TMS service. My source images are in either GeoTIFF or MrSid format, and are satellite imagery for adjacent areas which slightly overlap. I have successfully set these up in GeoServer as data sources and layers, and then made a Layer Group which combines each individual image layer into a single group so I can easily get tiles for anywhere in the coverage area via a single TMS request.
My problem is related to nodata areas, which are black in the individual images, at the borders of each image file where there is an overlap with the next image. For the GeoTIFF layers, I can easily set the InputTransparentColor in the GeoServer Layers → Coverage Parameters screen, and this works great with the combined layer group correctly serving the actual data rather than the black pixels for tiles where two images overlap. However, for my MrSid images, there is no InputTransparentColor option in the Layers screen, and when I get border tiles with TMS requests I am often getting the black pixels in preference to the actual data where tiles overlap.
So my question is basically is there any way to set the InputTransparentColor for layers based on MrSid data sources, or is there something peculiar to this format that prevent this option from being set?
I also see the same problem if I get a tile layer preview from the web interface, but interestingly if I ask for a layer preview (rather than a tile layer preview) the I do not see the problem, and the image layers blend correctly at the borders. I wonder then if the problem might be related to the way GeoWebCache requests the images from GeoServer in a way that causes the nodata to take preference somehow?
System details:
GeoServer 2.2.2 from windows installer
GDAL extensions
Windows XP
Oracle Java 1.7.0_09
Thanks in advance for any help!
Tim
Ciao Tim,
please, find my aswer inline below....
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Wed, Nov 28, 2012 at 4:08 PM, Tim Hayton <tim.hayton@anonymised.com> wrote:
I would suggest to use the ImageMosaic plugin.
I am assuming the images have:
- same CRS
- same data type
- same number of bands
- similar resolution
With the ImageMosaic plugin you do not need to use the layer group and
your GetCapabilities will be much smaller.
ImageMosaic handle the transparent color both on put images as well as
on the output image. Check the layer configuration.
Last but not least it does handle MrSID as well as GeoTiff files.
InputTransparentColor in the GeoServer Layers -> Coverage Parameters screen,
overlap.
See suggestion above about using ImageMosaic. That said you are right
there is no support
for input transparent color on GDAL Formats. Could file a jira
enhancement report for this?
It would be dead easy to add it and I believe we should do it right away.
System details:
GDAL extensions
Windows XP
Tim
MIRA Ltd
Watling Street, Nuneaton, Warwickshire, CV10 0TU, England
Registered in England and Wales No. 402570
VAT Registration GB 100 1464 84
The contents of this e-mail are confidential and are solely for the use of
the intended recipient. If you receive this e-mail in error, please delete
it and notify us either by e-mail, telephone or fax. You should not copy,
forward or otherwise disclose the content of the e-mail as this is
prohibited.
Keep yourself connected to Go Parallel:
INSIGHTS What's next for parallel hardware, programming and related areas?
Interviews and blogs by thought leaders keep you ahead of the curve.
http://goparallel.sourceforge.net
Geoserver-users mailing list
